Old 09-20-2012, 12:04 PM   #81
KRatcliff
Liked 534 Times in 143 Posts
Default Re: New cars, old cars and horsepower ratings.
I think you are overstating number 2. Anyone that has spent as much time on a carb car as I have mine is just as fast. Look at Tracy Pedigo for example. His car makes slightly more HP per cubic inch than mine does.
KRatcliff is offline   Reply With Quote
Old 09-20-2012, 12:16 PM   #82
Andrew Hill
Andrew Hill's Avatar
Liked 174 Times in 39 Posts
I don't understand the need to lower the indexes even further, why would we want to lose racers when Indy is almost always the only race with a full field anymore?
As far as separating the fuel injected cars from the carbureted cars, it's not fair to the guys with fairly factored fuel injected cars, and it would get rid of some really close races, especially in A-C. I don't see any reason why a 397/375 and an LS1 should not run heads up.
3207 D/SA, C/ED
Andrew Hill is offline   Reply With Quote
Old 09-20-2012, 12:25 PM   #83
Marvin Robinson
Marvin Robinson's Avatar
The point is not how well you can make the car run, but how easy it is to make changes. I have run a FI car, and making changes by pushing buttons is a lot easier than changing jets, adjusting timing with a light, etc. That may turn out to be a non issue for most racers, I'm just making the observation....
Marvin Robinson
3188 STK/SS
Marvin Robinson is offline   Reply With Quote
Old 09-20-2012, 12:30 PM   #84
Marvin Robinson
Having the indexes more accurately reflect performance I think is a good thing, the relative performance of the cars will still be the same, but I think a field with the cars .4-.7 under at the top is better than 1 second plus.
I agree.... this is a case where the factors are close to correct.... the problem keeps coming back to having accurate/fair factors.
Marvin Robinson
3188 STK/SS
Old 09-20-2012, 12:39 PM   #85
Ed Wright
Ed Wright's Avatar
So, your problem is with the physical effort involved? LOL
Ed Wright 4156 SS/JA
Old 09-20-2012, 12:45 PM   #86
Marvin Robinson
Don't have a problem with the effort (I went back to a carbureted car), just the amount of equipment and time it takes, especially when time is short. (That's the bracket racer in me talking, those late rounds tax your prep time, and at my old home track, dial-in changes were NOT allowed, so you couldn't use shoe polish to "tune" your car)
Marvin Robinson
3188 STK/SS
Old 09-20-2012, 12:51 PM   #87
KRatcliff
But your solution is equating it as a performance advantage. Just because you do it differently doesn't mean a person is doing it right. Tuning a carb car or a FI car properly is a pretty level playing field.
Old 09-20-2012, 01:20 PM   #88
KEN BUGAJ
Liked 18 Times in 7 Posts
Look if you want more car's in stock and more people in the stands than add some crate motor's !!
GM 502/502,502/450,385/390 ,350/330
add 3 or 4 Mopar and Ford crate motor's
Look I know NHRA Div. 1 has alot of car's , when you draw from 4 or 5 million you can get that many.
But Div. 2and some others have a problem with car the count.
Why not try it at the Div. 2 points races and see how it works out.
Heck if you add 20 or 30 car's to a div. race you'll add what ? another $8000. or $9000.
to help the track stay in business.
I would love to see a 56/57 chevy with a 350/330 runnig l crate motor.
The people in the stands don't care what motor is in that 56, just that it pull's the wheels and looks fast.
Just an Idea,,,,,
KEN BUGAJ is offline   Reply With Quote
Old 09-20-2012, 01:28 PM   #89
Marvin Robinson
Agreed... there is not a performance advantage (that was not my point), just easier and faster with a laptop rather than a toolbox. At my old track, in the final (round robin) rounds, it could make the difference between making an adjustment, and having to pass on the opportunity.
Marvin Robinson
3188 STK/SS
Old 09-20-2012, 01:35 PM   #90
KRatcliff
I can never remember making tuning adjustments in the later rounds. We are talking the NHRA, right? They do allow dial changes in any rounds unlike your home track. And that is a moot point because your individual class changes would be for heads up matches.
All in all I cannot follow your logic.
