Old 09-20-2012, 01:28 PM   #1
Marvin Robinson
Marvin Robinson's Avatar
Default Re: New cars, old cars and horsepower ratings.
Originally Posted by KRatcliff View Post
But your solution is equating it as a performance advantage. Just because you do it differently doesn't mean a person is doing it right. Tuning a carb car or a FI car properly is a pretty level playing field.
Agreed... there is not a performance advantage (that was not my point), just easier and faster with a laptop rather than a toolbox. At my old track, in the final (round robin) rounds, it could make the difference between making an adjustment, and having to pass on the opportunity.
Marvin Robinson
3188 STK/SS
Marvin Robinson is offline   Reply With Quote
Old 09-20-2012, 01:35 PM   #2
KRatcliff
Liked 534 Times in 143 Posts
I can never remember making tuning adjustments in the later rounds. We are talking the NHRA, right? They do allow dial changes in any rounds unlike your home track. And that is a moot point because your individual class changes would be for heads up matches.
All in all I cannot follow your logic.
KRatcliff is offline   Reply With Quote
Old 09-20-2012, 02:18 PM   #3
Marvin Robinson
I admitted earlier that these concersn were from my old bracket racer habits... at my old track, you qualified at 11:00am (it was not an all run bracket race, the 32 closest to their dial-ins ran for the money), and no changes to your dial were allowed. By 7:00pm, there might be a huge change in air/temp, etc, and you might need to adjust to hit your number. (Some would dial soft, but they usually were easy to make run under in eliminations when the air got better in the evening). This is not an issue, just pointing out that you can make a change on a computer car in just a minute or two with a laptop, or even get a tuning map from a friend or teammate and use it, while the same procedure in a carbureted car takes a lot more time... in today's NHRA S/SS, a different environment, not a factor.
Marvin Robinson
3188 STK/SS
Old 09-20-2012, 01:40 PM   #4
treessavoy
Liked 4 Times in 4 Posts
I think a better answer for the "old" cars would be to lower their weight until they were competitive again or lower weight and hp so they could stay in the same class.
Just a thought.
JimR
Jim Rountree
Old 09-20-2012, 02:05 PM   #5
Ed Wright
Ed Wright's Avatar
Just a thought.
JimR
Or, just rate the new stuff realistically?
Ed Wright 4156 SS/JA
Old 09-20-2012, 02:45 PM   #6
Jeff Lee
Jeff Lee's Avatar
Could we stay focused on the subject? Start a thread in tech about tunning your carbs or FI. This thread is supposed to revolve about ideas to keep the older cars in attendance.
Right, wrong or indifferent to NHRA adding the Super Cars, they are here to stay. I firmly believe (again, right or wrong, that's my opinion) NHRA doesn't want S/SS to go away, nor do I believe they want to see the "traditional" cars to fade away. I'm of the opinion NHRA is somewhat concerned about the top heaviness of the Super Cars and are open to debate amongst the S/SS committee to find a reasonable solution. As stated earlier, no solution is foolproof but I believe something can be worked out which will benefit many.
Logistically, I can't see any way NHRA would want to ad another class such as Stock GT to park, much less police.
I believe the factories are behind seeing more heads up runs and do not like the combo races based on my own conversations and also hearsay.
All issues combined can be resolved with combining sticks and autos & lowering the HP of the older vehicles. Things like Stick or auto HP standards can be worked out (those I've spoken to & myself don't care which HP is used or split the difference) and a 5% drop in HP would find a lot of cars approximately 150#'s lighter.
To summarize, the face of Stock doesn't change with HP changes. It's easy & across the board.
Combining sticks and autos leads to more heads up runs and most likely an increase in competition and less lifting.
For it or against it, let your representatives know your thoughts.
Jeff Lee 7494 D/S '70 AMX
Old 09-20-2012, 03:29 PM   #7
Marvin Robinson
Jeff,
Why tamper with the maybe 4000+ combos that the older cars represent, just change the factors on the new cars, and you only have to deal with about 25-30 combos. Limiting the factory engine combo game would help.... some of those Ford combos are actually factory GT/Stock cars already (a 352 or 428 Mustang???). Making the adjustments where the problem is, is the way to go
Marvin Robinson
3188 STK/SS
Old 09-20-2012, 05:36 PM   #8
M Brand 505B
Liked 31 Times in 10 Posts
To stay on point....
All "production" cars post 2008 need to have their own class designations. When the fastest pre 2008 cars are being outran by 0.20+ there is an issue!
Everyone who has a stocker or superstocker should be able to somewhat agree that having the big three making production race cars is good for the sport. But with the HP ratings they've been given its unfair for us to compete against them on a heads up basis.
Michael Brand II
505B - F/SA
M Brand 505B is offline   Reply With Quote
Old 09-20-2012, 05:46 PM   #9
Marvin Robinson
AMEN... we keep coming to the same conclusion. The BIG problem is the HP factor for the newer cars.
Marvin Robinson
3188 STK/SS
Old 09-20-2012, 05:57 PM   #10
Jeff Lee
Jeff Lee's Avatar
Jeff,
As I stated, NHRA is not going to step on the toes of the OEM and the new Super Cars. Again, that is my opinion. Like it or not, the AHFS is the platform these cars were built on and approved by NHRA. The OEM's submitted some HP figures and NHRA rejected some and negotiated on the others. I can't see NHRA doing anything on these cars other than allowing the AHFS to do it's job.
A keystroke will reduce the HP on the older cars. Me, personally, it wouldn't matter what defines "older" cars. I mentioned previously 1992 (Pre-LT-1 SBC) but if 2008 (First Drag-Paks), fine. Either 1992 or 2008 seems reasonable to me.
