Old 02-10-2023, 10:04 PM   #1
GrapeApe7575
GrapeApe7575's Avatar
Liked 341 Times in 77 Posts
Default Practice Tree Hookup
Anybody here have experience with setting up a full size practice tree for foot braking? I have a two step and a brake pressure switch but everything else in the system is mechanical.
My Final Round practice tree has a foot switch but it is not at all realistic and I'm trying to setup a true in the cockpit environment for practicing.
GrapeApe7575 is offline   Reply With Quote
Old 02-12-2023, 11:55 AM   #2
modelman1960
Liked 55 Times in 22 Posts
Default Re: Practice Tree Hookup
Contact Portatree timing systems. Even if the equipment isn't theirs, I'm sure they'll offer some technical advise for you.
Walt
Old 02-12-2023, 03:51 PM   #3
Bob Lasko
Bob Lasko's Avatar
Liked 186 Times in 55 Posts
Put a on off switch on the brake pedal that your foot will rest on.
Bob
Old 02-12-2023, 09:57 PM   #4
Jim Cimarolli
Liked 166 Times in 46 Posts
Bob
Thats what I did.
Jim Cimarolli is offline   Reply With Quote
Old 02-13-2023, 02:07 PM   #5
Bob Lasko
Bob Lasko's Avatar
Originally Posted by Jim Cimarolli View Post
Thats what I did.
Let us know how it works out
Bob
Old 02-15-2023, 01:51 AM   #6
TBear5033
Liked 112 Times in 16 Posts
I use my Porta-tree Eliminator and full tree, started with the transbrake cable then made a harness to tie into the brake pressure switch to activate the practice tree with the pedal, just like it would the 2 step and it works great - just like on the starting line
TBear5033 is offline   Reply With Quote
Old 02-15-2023, 02:48 PM   #7
bsimms89
bsimms89's Avatar
Liked 72 Times in 20 Posts
Did the same thing, I have my porta-tree eliminator with a full tree, ran a second wire from my brake pressure switch to this input from porta-tree: https://portatree.com/product/transb...tion-1-8-plug/
So the brake pressure switch runs the practice tree.
bsimms89 is offline   Reply With Quote
Old 02-15-2023, 05:22 PM   #8
Rob Petrie E395
Liked 216 Times in 77 Posts
Before pressure switches. I used a transbrake switch mounted to the brake pedal to activate my 2 step and practice on my practice tree. Basically it’s a piece of 1/4 thick 3”x3” aluminum angle. That is bolted to the back side of the pedal and the arm that comes down from the pedal pivot. It works very good and is inexpensive. I have a good picture of it. But can’t get it to post. If someone wants to see it and post it. PM me a phone number or email address and I’ll send it.
One word of caution. If you goto a Footbrake race. Tell them in tech what’s up or the crybabies will have a fit.
Old 02-16-2023, 11:19 PM   #9
Pete Lanciers
Pete Lanciers's Avatar
Liked 627 Times in 156 Posts
Mark,
I believe you employ a pressure switch that triggers your two step...You do not require an additional switch. If you have it wired as I do it provides 12v to your two step for activation. I've seen some that were wired to provide a ground to a two step that's already hot (not a good idea). So if my memory serves me right and you are wired like me tee into that line and present it to the tree footswitch connection. If your tree operates on a lower voltage like 9v's we'll have to step it down but its no biggie... Give me a call if you have a voltage mismatch, i can talk you through it.
Pete Lanciers
PAL Automotive Racing
Stock 7801
Pete Lanciers is offline   Reply With Quote
