Old 08-02-2016, 12:22 PM   #1
cal
cal's Avatar
Liked 31 Times in 18 Posts
Send a message via AIM to cal
Default Trailer lift shutters when going up, blows breaker
Hello All
I have a Stinger by Axe lift in my stacker.
It starts out going up ok, then it will start to shutter and pop the relay breaker.
After a moment or two it will reset and go up again, it will again start to shutter and blow the breaker/relay. and stop.
I was told to check the bushing in the rollers and have done so, they appear to be tight.
I also was told to clean the tracks and the Plastic bushing and lubricate them with WD 40. which I have done. Neither of which appears to have helped.
Anybody had a similar problem? Does anybody know of someone that works on lifts in Southern MD area?
Thanks in advance
Cal
SST HR 1177
cal is offline   Reply With Quote
