Old 08-02-2016, 03:41 PM   #4
Mike Pearson
Mike Pearson's Avatar
Liked 1,937 Times in 582 Posts
Default Re: Trailer lift shutters when going up, blows breaker
The 12 v system will require a very high amperage draw. Even the smallest issue with the wiring can cause problems. Have you checked the battery to see if it is up to the task. Some of those lifts have a capacitor in the motor to help with start up. Check the voltage with the motor in operation to see if there is a significant voltage drop. You might also replace the breaker. They can go bad when they are overloaded
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
