Old 06-09-2011, 08:27 AM   #1
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
Default Sunoco supreme
race fuel, i have been using this fuel for some time but need to know if there are any other fuels that can help pick up the ET a little more.I am pretty close to the index at 10.55 but have not tried any other fuels to see if they help (mostly because of the expense)but if there are any that has used Sunoco supreme and pick up ET using other fuels i will sure try it.
astikhossw is offline   Reply With Quote
Old 06-09-2011, 09:55 AM   #2
njk53
Default Re: Sunoco supreme
To be honest we did not see any difference between the Sunoco Standard 110 Octane @ $6.58 a gallon and VP 110 @ 12.00 a gallon. If you look at a chart that contains all of the fuel attributes that are legal for NHRA racing fuels for stock/super stock, I don't see a whole lot of difference.
Nelson Kowal
Stock 345
Old 06-09-2011, 10:14 AM   #3
Ed Wright
Ed Wright's Avatar
You might try VP C11, you will probably have to fatten it up a bit. My car prefers that over Sunoco.
Ed Wright 4156 SS/JA
Old 06-10-2011, 02:43 AM   #4
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Sunoco Supreme & C12 are close to one another in preformance....C11 MAY pick the car up....it will want less timing then Sunoco.
Old 06-15-2011, 05:31 PM   #5
tim worner
Liked 126 Times in 20 Posts
We use Sunoco purple in both cars. Found Sunoco blue and C11 & 12 just to cost more.
Tim Worner SS 1747
tim worner is offline   Reply With Quote
Old 06-15-2011, 09:23 PM   #6
Chris1529
Liked 70 Times in 29 Posts
I ran C-11 last year. I run Sunoco Purple now. My car seemed to fire better on the C-11, but runs the same on the Sunoco. Half the price to boot.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 06-15-2011, 10:10 PM   #7
The Hawk
The Hawk's Avatar
Liked 249 Times in 109 Posts
WOW! I`ve been paying 8.05 a gallon at a local track for Sunoco Purple. What`s everyone else been paying for "Purple"?
Lane Weber
Old 06-15-2011, 10:26 PM   #8
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Sunoco supreme
Sunoco Purple also seems to be one of the more "stable" fuels. Never had a problem with it in fuel check.
Old 06-16-2011, 09:58 AM   #9
Mike Croley
It's possible to pick up ET slightly by changing fuels , even brands of fuel . The pick up could come from increased torque , increased power , better throttle response , or a little of all of the above . Usually , any pick up you see will be due to the new fuel being a little more compatible with your engine specs and set-up .
And yes , some brands of race fuel are a lot more expensive than others. But spending a lot more isn't really necessary . Compare race fuels that offer the motor octane you need .
Mike Croley is offline   Reply With Quote
Old 06-16-2011, 02:19 PM   #10
njk53
Mike you are absolutely right. If you have a car that is a 9:1 or 9.5:1 it is going to be less sensetive to fuel compared to a motor that is 12.5:1.
Our motor is 9:1 and I'll be willing to bet we could get it to run pretty good on a fuel with a lot less octane rating than 110.
Nelson Kowal
Stock 345
