Old 02-10-2022, 10:13 AM   #11
KRatcliff
Liked 534 Times in 143 Posts
Default Re: Access to AMA Shipping Weights?
Originally Posted by Allen Wilson III View Post
It does give the combo an advantage that it can run in a class that it shouldn't be allowed to run if the shipping weight is not correct. I'm not claiming to be a shipping weight expert.... but it helps the entire LT1 combo avoid heads-up runs and HP adjustments. If it's not an advantage, then why not just go to GT rules?
Please explain the bolded part. How does it help the entire combo avoid heads-up runs and HP adjustments? There are a lot of fast cars in A through E. The 2015 VIN Camaro and LS1 Vettes come to mind plus many others IE Larry's combo. There are a lot of them out there.
It appears to me that this aspect hasn't changed one bit. Another question. Do you think the LT1 automatic combo needs another HP adjustment added to it?
KRatcliff is offline   Reply With Quote
