Old 02-10-2022, 05:51 PM   #11
KRatcliff
Liked 534 Times in 143 Posts
Default Re: Access to AMA Shipping Weights?
Originally Posted by Bryan Worner View Post
This is a real easy one to explain so I’ll tackle it! Firebird can run SS/HA, Camaro can’t! So when they race each other, let’s say in the final of a national event, or a must win round in a points race, they won’t race heads up! Therefore, neither will have to lean on their combo, which is the same in both cars, to secure that all important round win! So they just race each other in bracket mode and continue on with the same factor. Allen, is that a good explanation???
I have thought a little more about your explanation and tying it to Allen's comment. I think your explanation is valid, but narrow in the scope that you are comparing the same engine combination in a Firebird vs. a Camaro that are not running in the same class due to weight breaks. Thus eliminating a head's up situation, but I didn't read Allen's question as being that narrow.
Maybe he meant it to be as such, but he simply said "it helps the entire LT1 combo avoid heads-up runs and HP adjustments" which I contend that is not true. The head's up runs are not limited to the same combo they could be any combination in your respective class as you know. That was why I answered that the more classes a LT1 can compete in the greater odds of a heads up run with one of the other combos and it would affect the entire LT1 family in both the Firebirds and Camaros if triggers are hit or the average is affected.
KRatcliff is offline   Reply With Quote
