Old 01-05-2022, 03:16 AM   #4
john ancona
john ancona's Avatar
Liked 185 Times in 56 Posts
Default Re: Explain to me again, please
Originally Posted by 1347 View Post
Most don't want solid roller cams in stock, just go back and read posts about it in the past. Opening up that box will get you one more step closer to making a stocker engine a super stock engine with a lift rule.
Then put the rules back ,and most will wine about that , in case you haven't noticed stock is already Super Stock ,the lifters will not change fact that stock has gotten way out of hand ,you stated Open up that box will get one more step closer to making a super Stock engine with a lift rule , well, you and others better look again if we are only the lift rule away if we change the lifters what about the other enhancements to stock over the years to get us all to this point ,You freely use the word most ,would they be the guy's that are cheating spending lot's of money to cheat are they the ones that you call most ! The point you ,and others are missing ,and it is still the same as it was back in 2016, and even before that the old cars are at a disadvantage you ,and others may just want to see them disappear while you drive a late model race car with roller lifters ,and have others that can't aford to keep dealing with the lifter problem !
John Ancona 717 STK / SS
john ancona is offline   Reply With Quote
