Old 12-23-2021, 07:03 PM   #11
SDT1DYI
Liked 456 Times in 148 Posts
Default Re: New AHFS
Originally Posted by west coast View Post
Wow you guys are all a bunch of negitive Nancy's typing on your key boards like chicken little running around yelling the sky is falling. You all complain about the AHFS not working, when NHRA makes a change to make it work better to get underfactor combo's inline(which they created when they factor new cars) or they created with a stroke of a key board like the ford 302. which happened years ago and most of those combo's can still run -1.50 under. If it were not for Mike Graham the 302 would still be a -2.00 under combo. The change to the AHFS will only affect a very small percentage of the cars that race in stock. So all you Karen's can bash me now.
So James I went back and looked at the Qualifing Sheet at the Sept Divisonal at Boise. 37 Cars in Stock. 13 of the cars were more than 1 under. You were # 3. The 18th qualifer was more than .950 under so even with the recent changes to the Mineshaft rule it's still going to happen.
It could be time to adjust the indexes as NHRA did several years ago.
Steve Teeter STK/SS 620
SDT1DYI is offline   Reply With Quote
