#21 |
Liked 974 Times in 310 Posts
#65 qualified at .855 under Indy 2020.
#22 |
Liked 258 Times in 49 Posts
Like NHRA, there are very few heads up runs but there is a curve ball: you can't go more than a tenth faster than the quicker car qualified in a heads up.
Love vs tolerate comes to mind. Last edited by Albert Lee; 12-22-2021 at 03:36 PM. |
#23 |
Liked 172 Times in 81 Posts
Personally I think mineshaft should be weather related before it is placed into effect. Low temp, low humidity and high Barometer should be the trigger along with stiff tail wind.[/QUOTE]
So if the DA is less than the actual elevation of the track it's mineshaft?
Jim Mantle U/V/SA 6632 |
#24 |
Liked 68 Times in 24 Posts
Duane you have a PM.
#25 |
Liked 5,146 Times in 1,964 Posts
Yes.Let me clarify.
I should have spelled out what I meant. 2020 would not have met the new - .95 requirement, even though it was still a flat out deal. ;-)
#26 | |
Liked 1,026 Times in 281 Posts
So you work on your performance based class to have your car capable of running 1+ seconds under, you have a heads up and the #1 qualifier was .89 under. You ice, thin oil and all the other stops and run 1.10 all out, maybe because you had a worse light. What happens then? You lose? Or maybe you both run more than a .10 under?
Duane Hoven 1342 SS/GT |
#27 |
Liked 3,229 Times in 982 Posts
Think Al needs to clarify, never heard of this “curve ball”, in fact it sounds more like a screw ball or knuckle ball.
#28 |
Liked 2,361 Times in 558 Posts
The NMCA gives points for qualifying position. They WANT our cars to go fast!
The .10 rule allows for ice, etc. (If you didn't do that during qualifying)
Daren Poole-Adams NHRA Stock/SS 2007 |
#29 |
Clarifying "curve ball" heads up.
Car A qualifies 105 under, Car B qualifies 75 under. If heads up, both boards read 115 under and normal breakout rules apply. Just the messenger! AC |
#30 |
Liked 169 Times in 53 Posts
I'm a little bit confused; how can you break out on a heads up run?
Bill Bogues 4696 STK |
