Old 09-29-2021, 04:12 PM   #11
DeuceCoupe
Liked 48 Times in 44 Posts
Default Re: Project - NHRA Stock and S/S results 61-68
"...The 61 Cat/Ventura 389/333hp has a W/P of just over 11, which would run way down in H/SA=11.00 class in 1969..."
Don't know about the exact math. But that sounds reasonable.
Below is a pic of the Moore '61 368hp car. Caption says it set the F/S record in '69. So, if that caption is correct, then with a 333hp engine, it would have to run a lower class than F.
That sounds right.
3683/368=10.01 top of F/S=10.00 class
3683/333=11.05 top of H/S=11.05 (or H/SA if trans weight is ignored)
What I CANT find right now is where the 333hp car won or set a record.
But for sure, that combo is not way up there in the B/SA=8.00 class or even D/SA=9.00 class in 1969.
