#23 |
Liked 171 Times in 51 Posts
I checked the hub size compared to the wheel size, there is a difference however the wheel has a small step on the inside to accommodate the hub (see picture). I removed the hub and bolted it to the wheel it fits just fine, no binding or tight spots.
Original un-modified Aerospace hub. I purchased them new. Studs are Moser's not sure where they are made. I have ordered a set of Mark Williams which are manufactured by ARP. I always lock tight the studs on the hub as they are a true screw in stud without a head. I do cross my tie downs on the rear but not the front, didn't consider that might be too much side load. I made sure the small bolt pattern on the wheels matched the small bolt pattern on the hub. Fit is good putting the wheel on the hub. The first 18 months I raced the car there were no issues, then boom. Lot's of good ideas from you guys, I'll keep looking. Thanks
Kelly Lane Stk4991 |
