Liked 171 Times in 51 Posts
Nope, but the MW’s I ordered have a head.
Kelly Lane Stk4991 |
Liked 129 Times in 53 Posts
I think you got your solution right there,I have sheared a Moser stud for no real reason, looked like they had cut threads instead of rolled,I decided to go away from Moser totally at that point and got axles,spool,bolts and misc. stuff from M/W,just put the stuff side by side and you will never look back!
Stop global whining Last edited by Race Clean; 09-14-2020 at 01:55 PM. |
#3 | |
Liked 799 Times in 236 Posts
A headless stud is dependent on the threaded fit between stud and hub for alignment. Lacking a head, the stud is going to pivot in the hub thread and be loaded/twisted along it's length as the wheel nut is torqued. Not hard to imagine what happens then. -Al
"That'll never work....." Last edited by Alan Nyhus; 09-15-2020 at 08:47 AM. |
Liked 40 Times in 26 Posts
I have had this happen, a spacer between the wheel and the hub caused the studs to brake. I'm not sure from the pictures but, is there some kind of spacer on your hubs?
Liked 917 Times in 257 Posts
Granted I don't pay attention to what every company offers outside of my preferred sources, but I have never seen a headless stud offered for this application outside of the 5/8 drive studs using jamnuts of rear axles. Nor would I consider using them.
I don't want to bash anyone who supports racing, but that's a head scratcher. |
Liked 44 Times in 21 Posts
I bought some Moser studs for my rear axels, and i was not impressed with the quality.
Steven Barnes Stock 704 N/SA |
