Old 09-13-2020, 11:14 AM   #21
Signman
Liked 269 Times in 99 Posts
Default Re: Broken Front Wheel Studs
Just as a long shot
Do you cross tie downs when towing. Am pretty convinced those that tie down straight front and back not crossed allow a lot of side to side movement while towing which causes most of the wheel cracking.
It's a stretch but this would also put some stress on the lug studs.
Old 09-13-2020, 12:50 PM   #22
John Dinkel
Liked 263 Times in 68 Posts
Were the wheel studs made in China?
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 09-13-2020, 08:16 PM   #23
Shadylane
Shadylane's Avatar
Liked 171 Times in 51 Posts
I checked the hub size compared to the wheel size, there is a difference however the wheel has a small step on the inside to accommodate the hub (see picture). I removed the hub and bolted it to the wheel it fits just fine, no binding or tight spots.
Original un-modified Aerospace hub. I purchased them new.
Studs are Moser's not sure where they are made. I have ordered a set of Mark Williams which are manufactured by ARP. I always lock tight the studs on the hub as they are a true screw in stud without a head.
I do cross my tie downs on the rear but not the front, didn't consider that might be too much side load.
I made sure the small bolt pattern on the wheels matched the small bolt pattern on the hub. Fit is good putting the wheel on the hub.
The first 18 months I raced the car there were no issues, then boom.
Lot's of good ideas from you guys, I'll keep looking.
Thanks
Name:	Wheel Stud (12).JPG
ID:	55771   Click image for larger version
Name:	Wheel Stud (13).JPG
Kelly Lane Stk4991
Shadylane is offline   Reply With Quote
Old 09-13-2020, 08:27 PM   #24
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Mine have a regular head and come with washers with a chamfer on the ID . They are torqued and I use locktite . The picture of the Moser studs you have don't have a head. so do they come with a jam nut ?
Old 09-13-2020, 08:55 PM   #25
Shadylane
Shadylane's Avatar
Nope, but the MW’s I ordered have a head.
Kelly Lane Stk4991
Old 09-14-2020, 01:51 PM   #26
Race Clean
Liked 129 Times in 53 Posts
I think you got your solution right there,I have sheared a Moser stud for no real reason, looked like they had cut threads instead of rolled,I decided to go away from Moser totally at that point and got axles,spool,bolts and misc. stuff from M/W,just put the stuff side by side and you will never look back!
Stop global whining
Race Clean is offline   Reply With Quote
Old 09-14-2020, 07:43 PM   #27
Shadylane
Shadylane's Avatar
I agree the Moser studs look like low grade stuff. I have Moser axles and spool also. So far so good on them. My car is a low hp U/S car so I thought the stuff would hold up.
Kelly Lane Stk4991
Old 09-15-2020, 07:40 AM   #28
Alan Nyhus
Liked 799 Times in 236 Posts
A headless stud is dependent on the threaded fit between stud and hub for alignment. Lacking a head, the stud is going to pivot in the hub thread and be loaded/twisted along it's length as the wheel nut is torqued. Not hard to imagine what happens then. -Al
"That'll never work....."
Old 09-15-2020, 01:06 PM   #29
r429469
Liked 40 Times in 26 Posts
I have had this happen, a spacer between the wheel and the hub caused the studs to brake. I'm not sure from the pictures but, is there some kind of spacer on your hubs?
r429469 is offline   Reply With Quote
Old 09-15-2020, 01:57 PM   #30
CMcAllister
Liked 917 Times in 257 Posts
Granted I don't pay attention to what every company offers outside of my preferred sources, but I have never seen a headless stud offered for this application outside of the 5/8 drive studs using jamnuts of rear axles. Nor would I consider using them.
I don't want to bash anyone who supports racing, but that's a head scratcher.
