Old 01-13-2020, 07:42 PM   #1
MikeMoller
MikeMoller's Avatar
Liked 254 Times in 78 Posts
Default Re: Horsepower welfare changes.....
Originally Posted by jamie2370 View Post
Mike, I have the same question. Wording seems to state that once you get HP that you can NEVER get a decrease? Def needs clarification
What about combo's that were increased years ago? 1975 Chevy Monza with a 262/110 changed to 171 hp (auto) on 10/16/2012. Is this not eligible for HP decrease??
Mike Moller
NHRA 203 Q-R-T/SA
Old 01-13-2020, 08:32 PM   #2
Billy Nees
Barry, HP increases must be given on a percentage basis. You can't (well, you can, NHRA did for years) just give HP 3 or 5 or 10 at a time. As an example, a 3 HP hit to an A car (8.00 lbs.) is a 24 lb. weight penalty. The same 3 HP hit to a U car (20 lbs.) is 60 lbs.! Now look at your 10 HP hit, 80 vs. 200 lbs.!
Billy Nees 1188 STK, SS
Old 01-13-2020, 11:11 PM   #3
B Parker
Liked 2,343 Times in 465 Posts
Billy you are correct. My point was to make the system simple and so less games have to be played all year to avoid a hp hit. If you do go fast but not too fast you get a minor amount of hp not enough to ruin your combo. Something that would only make you have to carry about 20 pds. If you go real fast you get a hp hit to put you inline with what the hp should be for that combo.
The KISS rule should be in effort for the AHFS BP
Old 01-13-2020, 11:33 PM   #4
B Parker
I'm sure I'll get attacked for this one. But how many comb's in 600ft of air or less in a heads up run on kill do you think can go somewhere around 1:20 under. Maybe not your car but someone else that is running your combo. Here is something I don't want to see happen. Lets take the 1969 350/255 hp combo. There are a lot of them out there. And that combo has been beat on as much as any. Now Indy has shown the 350 combo is not the fastest in the class the last several years. So you get two H/SA cars one being the 350 and the other a Chrysler heads up in a later round at a race. Both are on kill and the air is good say 600ft. The 350 wins and only by .03 and goes 1.22under. The 350 is already not the fastest in the class so how much more weight and further behind do we want to put them. BP
Old 01-14-2020, 07:12 PM   #5
James Perrone
Liked 1,863 Times in 435 Posts
How about run class at divisionals
. More cars involved .
More chances for fast runs .
Think about it. With 60 cars at National events nobody gonna get HP
Usually the #1 qualifier will go 1 second under. And mineshaft happens
Also Indy needs to count. It’s the only race that people will go stupid fast.
This is a way to make the system work.
The sandbagging at a class race will not work.
james perrone 1290 STK
