Old 12-24-2018, 10:39 PM   #1
bigshow2966
Liked 181 Times in 56 Posts
Default Re: The best "Dime Rocket" combos!
Originally Posted by Coleydog View Post
318-2bbl, think I can get 300hp out of it, has it been done? I like the idea. Would put me in N-O or P depending on weight of course.
Mike
Mike Jeffrey and Bogners were helping a guy with a 318-2 combo. It was pretty tough sledding as I recall.
bigshow2966 is offline   Reply With Quote
Old 12-25-2018, 04:33 AM   #2
GTX JOHN
Liked 2,490 Times in 700 Posts
We run N O P with 318 Thermoquad @ 230 HP.
We tried 2 Brl. although did not change anything else
in engine. The wagon went from 1+ under to not being
able to run the index.
The Thermoquad is a great carb if you take the time to
understand it!
John Irving
741 Stock
741 Super Stock
Old 12-25-2018, 09:48 AM   #3
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
soooo, what do you guys think about a 70 Hornet with a 232/ stick combo? I seem to have one that's just begging for SOMEBODY to build....it might have to be ne...
Old 12-25-2018, 10:12 AM   #4
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
While it seems that would be good because of the 2-bbl carb, the '77 or '79 258 2-bbl makes more sense for only 5 more hp. they have 26 more cubic inches, bigger cam, better cylinder heads. Ed Fernandez and Jim Mantle have proven them as automatic combos.
Old 12-25-2018, 10:22 AM   #5
Billy Nees
Liked 7,854 Times in 1,750 Posts
Well, the newer 258s are better but if you have a 70 Hornet, I would say go for it! If you compare it to my 70 Chevy 230/140/140, everything is as good or better and I'm stuck with a 1bbl. and it ran pretty good.
Billy Nees 1188 STK, SS
Old 12-25-2018, 10:35 AM   #6
Tom keedle
Tom keedle's Avatar
the 232 is a single barrel carb motor...far as that goes, I've got a 73 258 out of a gremmy and a 77 258 that's out of a 77 amx (hornet) that are both 1 bbl engines. i'me wondering if it would be worth swapping cranks with the 232 so I could get a scattershield….kinda like my feet like to run a stick for the fun factor and BTW Dwight, I've got your nuts....i'll get them sent this week
Old 12-25-2018, 10:40 AM   #7
Billy Nees
OK?
70 232 lists 1bbl and 2 bbl both at 145 HP.
Old 12-25-2018, 11:09 AM   #8
Tom keedle
Tom keedle's Avatar
OK?
I see that now...although a wcd ain't my favorite carb, I did learn a few things about them...it'll take some looking to find an intake...
Old 12-25-2018, 01:29 PM   #9
Liked 5,145 Times in 1,964 Posts
I suppose, seeing it's Christmas, I ought to be more charitable.
Okay, you've got the car and want to race it. Better than sitting behind a keyboard all the time. I know that story.
Anyway, so what are your plans for this thing? Where will you test it at a reasonable altitude? Kearney is 300 miles, right?
How about the clutch? Trans and shifter? Rear end?
The reason I ask is because Stick shift / Dime rocket doesn't necessarily go together. You know , like jumbo shrimp? Rap music?
Old 12-25-2018, 03:06 PM   #10
Nick Heath
Liked 576 Times in 137 Posts
Maybe it'll take more work than some of the others mentioned...but I still want to see someone try the '96-'98 Mustang 3.8 V6.
