Old 05-17-2018, 02:37 AM   #15
wagonboy
Liked 26 Times in 5 Posts
Default Re: Front tire pressure adjustments
KD,
I would highly recommend using your 2 step. If you can lower the launch rpm that would be a great help to you. Also, I would it would be more consistent leaving at the same RPM each time. The converter can move a little with air changes and trans temps.
Hook up a micro switch that will only allow the 2 step to be activated in low gear. I have mine on my shifter.
Good luck out there and keep trying, it will come.
Ryan
wagonboy is offline   Reply With Quote
