Old 05-16-2018, 09:15 PM   #1
Kdw1403
Liked 68 Times in 22 Posts
Default Re: Front tire pressure adjustments
I have 28 inch tall tire on it. Car went 1.33 60 ft this past weekend. Just didn’t know what other B/SA cars run for tire pressure. I run radials on rear.
Kdw1403 is offline   Reply With Quote
Old 05-16-2018, 10:39 PM   #2
Ed Wright
Ed Wright's Avatar
Blocking, or bias slicks should help.
Ed Wright 4156 SS/JA
Old 05-17-2018, 12:16 AM   #3
Kdw1403
Blocking? Are you talking about some sort of a blinder? If so , I really don’t know how to do that. I have seen and heard of people doing that. Are they blocking out the top 2 bulbs ? Do you then use the bottom bulb like a pro tree? What kind of device do you use to block out the top 2 bulbs? I also do not use a 2 step. I just lean on the converter. My 2step button is on my brake pedal. I have always been afraid I would hit the button and activate my 2 step at the finish line. Do you set the low side 2 step low enough where your brakes can safely hold the can without pushing it out of the beams. ?
Old 05-17-2018, 12:42 AM   #4
Okay, if you're not blocking or blinding, let's leave that for another day.
Now, by your own description, you're swinging across .000 by about 35 thou.
So let's say you slow your vehicle reaction down .035. Your - .020 now becomes a +.015
Great.
But what happens when you hit what used to be a +.015? It now becomes a + .050.
Not going to win too many that way either.
My friend, I think you need to work on something other than the car right now.
Just my opinion. I don't consider myself to be a bracket racer. I did win a couple of track championships, but I think I'll let the experts take it from here.
Later ,we can get back to the technical items.
Old 05-17-2018, 01:14 AM   #5
Kdw1403
Yes mark you are correct in determining that my slower lights would be less than stellar. I would rather have more ‘50’ lights and less red lights. Most people would rather have a 50 light than a red light. Most people are not as consistent as you on the tree. We all wish we were but we are not, at least I’m not.i I can read between your lines and I will continue to work on my driving as hard as I can. Hopefully I can get my cars reaction time to go along with my ‘human’ reaction time and get a win one day. Thanks mark.
Old 05-17-2018, 02:37 AM   #6
wagonboy
Liked 26 Times in 5 Posts
KD,
I would highly recommend using your 2 step. If you can lower the launch rpm that would be a great help to you. Also, I would it would be more consistent leaving at the same RPM each time. The converter can move a little with air changes and trans temps.
Hook up a micro switch that will only allow the 2 step to be activated in low gear. I have mine on my shifter.
Good luck out there and keep trying, it will come.
Ryan
wagonboy is offline   Reply With Quote
Old 05-17-2018, 07:21 AM   #7
Kdw1403
Thanks Ryan. I think you are correct. I’ll check into hooking up that switch.
Old 05-17-2018, 01:06 PM   #8
Mike Gray
Mike Gray's Avatar
Liked 691 Times in 199 Posts
Great.
Good advise here. Your car if set up the same each run is going to react in just about the same amount of time each run, the variable is the driver. I worked my super gas car down to decent repeatable lights on a Pro tree. I then ran it in super street and was consistently early. (I needed to adjust the car to the slower light) That was accomplished with making changes to the car. Then I went and ran some full tree classes and I was all over the place. The car was still the same and I knew it could cut decent lights on either Pro tree. The difference in the full tree races was squarely with the driver, me. I needed to find a way for the driver to be better at reacting to the full tree, blocking or leaving on the top bulb are some of the ways to accomplish that.
Old 05-17-2018, 12:20 AM   #9
Kdw1403
Blocking? Are you talking about some sort of a blinder? If so , I really don’t know how to do that. I have seen and heard of people doing that. Are they blocking out the top 2 bulbs ? Do you then use the bottom bulb like a pro tree? What kind of device do you use to block out the top 2 bulbs? I also do not use a 2 step. I just lean on the converter. My 2step button is on my brake pedal. I have always been afraid I would hit the button and activate my 2 step at the finish line. Do you set the low side 2 step low enough where your brakes can safely hold the car without pushing it out of the beams. ?
