Old 12-08-2016, 10:39 AM   #11
Alan Nyhus
Liked 800 Times in 237 Posts
Default Re: Lifter rule in Stock
Originally Posted by Grey Ghost View Post
Here we go. Why do the hyd cam combos get an "up grade" and not the solid cam combinations?? IF ( I am not advocating for this) everyone had been up graded to rollers would that not have leveled the playing field? Am I missing something here? Are not the lifter concerns "wiping out a motor" shared with solid and hyd cams?
Hi Phil.
In a way, a hydraulic cam switched to solids actually loses lift when checked the NHRA way. Since the NHRA checking clearance is .000 (zero), a solid cam loses the lift from the lash when it's running.
A hydraulic lifter is theoretically always at .000 (zero) when it's running.
"That'll never work....."
