Liked 133 Times in 76 Posts
Looking for actual front tire measurements of 25"&26" tires. My Phoenix 26" are 84" measured with a tape arond the center of the tire. I'm looking to drop down for better RT's.
Stick or automatic? If your lights are late, I would work on myself or the car. Those are shorter than mine. 26.75" diameter is 84" around with a tape measure. Mine are 28" tall. (88" circumference) Personally, I would not shorten my tires to make my lights look better. There are much smarter people here than me, that may tell you different.
Ed Wright 4156 SS/JA |
#3 | |
I work on the car and myself regularly. Frt. tires are worn out so I need new ones anyway.
If anyone could put a tape on their tires i'd appreciate it. |
Liked 10,835 Times in 2,252 Posts
To get a rough idea C= 3.1416 X Dia.
Liked 55 Times in 29 Posts
Running a smaller front tire is an example of working on the car. There is no magic dust that will instantly give you better results, but every bit helps. You won't know till you try.
My 26" Hoosiers measure 81-1/2", inflated to 34 psi on a 3-1/2" wheel. I looked at your measurement again before posting this and saw the big difference, so I measured again, 81-1/2".
Jeff Blanchard 353C / Stock |
If you need small front tires to get a good reaction time, your doing something wrong, or have a very slow car.
Liked 8,106 Times in 1,531 Posts
Liked 16 Times in 11 Posts
On my time slip, i prefer get three right LETTERS (win) VS to 3 right NUMBRERS (best time)
