Liked 747 Times in 362 Posts
TJ used the EZ name thru the '78 season, then changed it to "Born Again". One pic below shows her blasting off at I-20 Dragway in Tyler, Texas, in '79.
The other pic shows her '67 Bird which ran a best of 11.82 in '88. Beginning around '76 into '77, all the local tracks we ran switched to bracket only, with very few exceptions. They did have an IHRA points race in Tyler in '78. But they also ran a 16 car bracket field at that race. TJ won it from the #16 position. ![]() Last edited by oldskool; 01-18-2015 at 12:30 AM. |
Liked 154 Times in 37 Posts
Mark probably has more insight on this --but--We looked at that 75-76 455 but if I'm not mistaken the head CCs jumped about plus 20 CCs from 1974. At a loss of about 2 compression ratios we decided to pass.
66W30POST |
Guest
Posts: n/a
68 Firebird. The 400 combo rated at 327 like Brent runs can run the index without much trouble or expense. If you want it to be a killer, then you need a good trans converter and some testing time and effort. You will have to rpm these some to make them run well.
the 350 combo could be an interesting deal. Good compression, better heads for the smaller size. 305 is a good place to start with these. This should run the index without much trouble. Parts should be easy to find, as well. Either car you build should get you into the game without a munch of expense, getting to the next level is the harder part. Expense wise Last edited by Todd Hoven; 01-18-2015 at 09:52 PM. |
We'll get around to possible 350 and 400 combos later. But since I already have a couple of 455's together, I wanna discuss 455 combos some more. I already mentioned using a '76 TA.
But now I wanna explore the possibility of using one of the heavier bodies. One of my Pontiac heroes from the old days was Jack Mullins. We saw him run at a points race in Jackson, MS in the mid '70's. He ran a screamin 389 and a 4-speed in a big heavy wagon. Jack won some big races. I think it was at the US Nationals where he beat the factory Mopar driven by Judy Lilly(Miss Mighty Mopar). I think he was responsible for several hp refactors on the 389 Pontiac engine. Another famous Pontiac racing wagon was the "Tons a Fun" Lemans wagon. I think Gary and Charlene Wood both won races in this wagon--actually there were at least 2 of them. http://www.hotrod.com/cars/featured/...ntiac-history/ I can see at least 3 advantages of using a wagon. (1) They are heavy, putting you in a much lower class. (2) A lot of that weight is in the rear, which should help increase traction. (3) If you can find one that hasn't been crushed, it should be cheaper than a TA. Now there are several other big cars that were about the same weight as the wagons. Some of these had a real long wheel base--123". Some, like the Grand Prix, had a shorter wb--116" Now, my thinking is that the big cars with the real long wb would be the least desirable for a drag car. I would think that either a Lemans or a GP would be a little easier to hook up, than the big car with the longer wb. What do you guys think ? One other advantage I can see that the heavier cars might have is that you can run the stiffer radial slicks with a lot of air pressure. They will still hook because of the extra weight over the tires, especially the wagons. And the higher air pressure will produce less rolling resistance. After looking at the list of '76 models that can run a 455, it looks to me like the Lemans wagons with 116' wb might be the best choice. Next would be the 112" wb 2-door Lemans. Then the GP's. I'd say that the Cats and Bonnies with 123" wb would be the worst choices. http://www.classracerinfo.com/Engine...px?ENGINE=2107 Now, here's a question for you guys. The big wagons have a 127" wb and weigh 5000lbs. Is this just too big for Stocker ? Or can it still be competitive because of it's slower index ? Will all that extra weight be harder on parts, causing failures ? Also, do any of you guys know if the '76 Lemans and Lemans Wagons had the 8.5" rear end ? What about the GP ? Cat's, Bonnies, & Big Wagons ? ![]() Last edited by oldskool; 01-18-2015 at 02:20 PM. |
Now, I think all these '76 Pontiacs except for the Birds had coil spring suspension. The Cal-Trac type set-up seems to be pretty much std equip for today's leaf spring Stocker.
But how about the coil spring cars ? On my '69 GTO, all I did was stiffen the rubber bushings with finishing nails, and run air bags, with more air in the passenger side bag. It worked OK on a mid 12 sec car. http://www.jegs.com/p/Air-Lift/Air-L...43887/10002/-1 So what is the best legal set up for the coil spring suspension on one of these heavy cars ? If there are any aftermarket parts involved, please list brands and part numbers if you have them. Links to them would be great. Whether I use a coil spring car or not, there is probably somebody who will read this who can benefit from a detailed description of a good coil spring set-up for a Stocker. Thanks in advance for sharing this info with us. ![]() |
Liked 33 Times in 16 Posts
Variations of these work well... http://www.summitracing.com/parts/hal-5213/overview/
Rich Taylor I/SA - 321 |
#7 | |
OK, that's one vote for no hop bars. Is that what most of you coil spring guys are using ? |
Liked 61 Times in 25 Posts
Lots of companies that make great suspension components out there for A Bodies. Even though lowers can't be adjustable per the rulebook, adjustable uppers, a good anti roll bar and shock package will allow you to make changes on the car as needed. This is just a couple of examples of companies that make great products.
http://trzmotorsports.com/wp2/?produ...sion-1968-1972 http://www.wolferacecraft.com/Search...?CategoryID=28 Last edited by Tony Corley; 01-18-2015 at 05:25 PM. |
#9 | |
(1) Does anybody have a link to a site or sites with pics and explanations and/or installation instructions for these devices ? (2) Is this what most of the quicker Stockers are running ? (3) Would these be required on a 4000 lb + car, such as a wagon ? Or will the large amount of weight make these extreme components unnecessary ? (4) The adjustable uppers that were mentioned. Does that mean that most cars need shorter arms ? or longer ? (5) Are the different length arms to change pinion angle, or suspension geometry ? (6) What about the coil spring "slapper' bars ? Are they totally useless for Stockers ? Sorry about my ignorance on this subject. I've just never used any of the above products. ![]() http://www.jegs.com/p/Competition-En...37234/10002/-1 Last edited by oldskool; 01-18-2015 at 06:09 PM. |
#10 | |
