Old 01-18-2015, 03:28 PM   #1
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: Ol' Fart's Firebird Fantasy
Variations of these work well... http://www.summitracing.com/parts/hal-5213/overview/
Rich Taylor
I/SA - 321
Old 01-18-2015, 04:05 PM   #2
oldskool
oldskool's Avatar
Liked 747 Times in 362 Posts
Originally Posted by HandOverFist View Post
OK, that's one vote for no hop bars. Is that what most of you coil spring guys are using ?
Old 01-18-2015, 05:15 PM   #3
Tony Corley
Liked 61 Times in 25 Posts
Lots of companies that make great suspension components out there for A Bodies. Even though lowers can't be adjustable per the rulebook, adjustable uppers, a good anti roll bar and shock package will allow you to make changes on the car as needed. This is just a couple of examples of companies that make great products.
http://trzmotorsports.com/wp2/?produ...sion-1968-1972
http://www.wolferacecraft.com/Search...?CategoryID=28
Tony Corley is offline   Reply With Quote
Old 01-18-2015, 06:06 PM   #4
oldskool
oldskool's Avatar
OK, I've seen these "anti roll bars" but I don't know exactly how they work.
(1) Does anybody have a link to a site or sites with pics and explanations and/or installation instructions for these devices ?
(2) Is this what most of the quicker Stockers are running ?
(3) Would these be required on a 4000 lb + car, such as a wagon ? Or will the large amount of weight make these extreme components unnecessary ?
(4) The adjustable uppers that were mentioned. Does that mean that most cars need shorter arms ? or longer ?
(5) Are the different length arms to change pinion angle, or suspension geometry ?
(6) What about the coil spring "slapper' bars ? Are they totally useless for Stockers ? Sorry about my ignorance on this subject. I've just never used any of the above products.
http://www.jegs.com/p/Competition-En...37234/10002/-1
Old 01-18-2015, 06:11 PM   #5
Tony Corley
This site is a good source for answering a lot of your questions.
http://www.baselinesuspensions.com/
Necessary to me would be anything that gives an advantage, but at the same time, I had a 71 Monte Carlo SS 454 back in the early 80's that would run 11.50's with 1.50 sixty foot times with nothing but air shocks on the rear, lol.
Old 01-18-2015, 06:24 PM   #6
HandOverFist
Aftermarket adjustable upper arms are legal, but you must use the factory front attachment point (no extra holes). The rear attachment point can be relocated.
Rich Taylor
I/SA - 321
Old 01-18-2015, 06:31 PM   #7
Tony Corley
You don't have time to be on here. You have 2 race cars to get finished and submit reports on , lol
Old 01-18-2015, 07:34 PM   #8
oldskool
oldskool's Avatar
Wow ! This blows my preconceived ideas out of the water. That site has some great info.
One of the main things I got from it that might pertain to a heavy coil spring Stocker is that if you are getting 100% traction without a lot of front end rise, then don't loosen up the front or use 90/10 shocks. What you want is to use all your power for propelling the car forward. If front end rise is not needed for traction, then your ET will be better if all your power is moving the car forward.
Also, I read that you want soft springs to help traction. But, this guy says that for a stock suspension coil spring car, you want stiff springs, so that all the weight is used to push the tires into the track. If the springs are soft, then on the initial hit, the body will squat, instead of pushing down on the tires. Makes sense to me.
And the part about the '71 Monte with nothing but air shocks: if I remember correctly, that was a heavy body style, very similar to the '69-'77 Pontiac GP. So, that may be a further indication that all these fancy suspension pieces are not needed for a HEAVY, low buck Stocker. Would probably be a good idea to start with stiffer bushings, stronger springs, air bags and stiff shocks--try that and see how it works, before spending a bunch on parts that may not be needed at all.
Old 01-18-2015, 08:13 PM   #9
Tony Corley
[QUOTE=oldskool;458884]Wow ! This blows my preconceived ideas out of the water. That site has some great info.
And the part about the '71 Monte with nothing but air shocks: if I remember correctly, that was a heavy body style, very similar to the '69-'77 Pontiac GP. So, that may be a further indication that all these fancy suspension pieces are not needed for a HEAVY, low buck Stocker. Would probably be a good idea to start with stiffer bushings, stronger springs, air bags and stiff shocks--try that and see how it works, before spending a bunch on parts that may not be needed at all. [/QUOTE
It worked, but think of how much quicker it might have been using todays suspension technology!!
Old 01-18-2015, 05:27 PM   #10
HandOverFist
Just for reference those were used in this '66 Chevelle 396SS. Basicly a street car with minimal mods...5.38 gear, TH350, Moroso front springs, running full street trim at 3800 + pounds. Best I remember was a 7.00 1/8-mile with a 1.50 60'...a real lead sled.
Rich Taylor
I/SA - 321
