#51 | |
Liked 101 Times in 52 Posts
Do they not use the actual run weight when calculating HP? If you are already getting factored at a weight heavier than you will be required to run in the future the system is even more flawed than many here feel it is:-) |
#52 | |
When mine is healthy I usually run it 140 heavy. I didn't need to as weak as it has been these last couple of weeks. I finally took all the weight out at Indy, and best it went was -.879. Need to get it back out of the car. I think know what it needs now, to get back where it was. Won't be as fast as Ricky's, but better than it is.
Ed Wright 4156 SS/JA |
#53 | |
Liked 282 Times in 103 Posts
#54 | |
Liked 1,034 Times in 368 Posts
BTW.... When Ronnie and I ran in the morning the Air was 2750.... I helped Rickey in the final and the air was 1000 feet worse and we had lost some tailwind.
Jeff Niceswanger 3740 SS |
#55 | |
Where is the "LIKE" button? |
#56 |
Liked 316 Times in 67 Posts
You can run heavy, but a few years ago you could not weigh more than the next lower class, i.e., I cannot run SS/MA at SS/NA weight. A minor point since hardly anyone runs that heavy, but at Norwalk about 3 years ago Travis held a meeting in the trailer at Tech explaning that
It may have changed I did observe a racer removing 200 lbs at Joliet one year...hard to do when its "welded in" |
#57 |
Liked 228 Times in 70 Posts
The 360 will receive 9hp. The old minimum weight for SS/IA was 2920. It will now be 3010.
#58 |
Don't think that will bother that car much, do you?
#59 |
Liked 57 Times in 14 Posts
How many cars actually run near minimum anyway? Not many, I'm guessing.
Mike Voth 5189 GTN - 5188 GTO Voth Racing |
#60 |
I'm usually 140 over, except the last four weekends where it had slowed down so bad.
Had all the weight out on the 10.12 pass. No weight, no restirctor plate, still slow. LOL Just need to get the car out of the trailer, and take it back apart. It's only money, right?
