Originally Posted by Bobby DiDomenico
Interesting Ed,
Do they not use the actual run weight when calculating HP? If you are already getting factored at a weight heavier than you will be required to run in the future the system is even more flawed than many here feel it is:-)
No, Bobby, a lot of us run heavy to avoid hitting the 1 under trigger and to keep our AHFS average down. They run that car more than 100 over weight anyway. As far as I know, NHRA doesn't monitor what we go across the scales at. Hope not anyway. :-)
When mine is healthy I usually run it 140 heavy. I didn't need to as weak as it has been these last couple of weeks. I finally took all the weight out at Indy, and best it went was -.879.
Need to get it back out of the car. I think know what it needs now, to get back where it was. Won't be as fast as Ricky's, but better than it is.
