Liked 20 Times in 14 Posts
As far as the camaro/firebird hp it is probably intended for the corvette as there are a few that has been going fast and rated far below their cousins! Look out corvette owners Nhra is coming for you! LOL!!
Liked 780 Times in 194 Posts
Liked 147 Times in 54 Posts
under the nhra stock car classification for 2003 chevrolet section the change is under "GT factors." at the top, it is the yellow highlighted change dated 1/1/14. at the risk of sounding nieve what is a "GT factor" in stock???
Liked 13 Times in 9 Posts
This is because of the new rule that you can only run combinations that don't exist in classes that don't exist.....
Liked 228 Times in 70 Posts
Upon my own research, I have gathered that the 405hp engine for GT was previously rated the same as the regular LS1, but the 405hp version has only one casting number for the head. This casting number is not the same as any other LS1 engine. Therefore this makes this combo different than the others. Is there 90hp more in this head? Absolutely not. However, it is listed with only one casting number for the head.
#7 | |
Ed Wright 4156 SS/JA |
#8 | |
Liked 393 Times in 153 Posts
edit: Just realised that SD is for naturally aspirated diesels, should of been SDT/C and SDT/CA Last edited by goinbroke2; 01-13-2014 at 12:31 PM. Reason: Forgot the powerstroke is turbo'd |
#9 | |
Liked 282 Times in 103 Posts
