#21 |
Liked 780 Times in 194 Posts
You better get clarification on what Mike says. "If it is oem design and size it is ok" says nothing definitive about pressure.
#22 | |
Liked 184 Times in 113 Posts
From: Michael Baker [mailto:mbaker@ihra.com] Sent: Tuesday, December 17, 2013 3:33 PM To: Daniel Fahey Subject: Re: Pure Stock Spring VS574 - Checking for Legality Yes Sent from my Verizon Wireless 4G LTE DROID Daniel Fahey So if the Spring Pressure is 30% above Stock it will be OK? Just so long as it is a Stock Replacement Spring! Correct? D Daniel Fahey - CEO President DanSources Technical Services, Inc. 1010 Rockville Pike, Suite 405 Rockville, MD 20852 301-217-0425 x 400 www.DanSources.com From: Michael Baker [mailto:mbaker@ihra.com] Sent: Tuesday, December 17, 2013 3:25 PM To: Daniel Fahey Subject: Re: Pure Stock Spring VS574 - Checking for Legality If it is oem design and size it is ok Sent from my Verizon Wireless 4G LTE DROID Daniel Fahey Hello Mike: Called Bullet Cams for advice⦠He asked me to confirm on my LT1 1995 SBC Engine. My Car runs G/Pure Stock. 1995 Impala SS. Looking at a replacement spring from Associated Spring VS574.. Lists as a LT-1 replacement spring. Need to know if it qualifies as a Pure Stock Legal Spring for my car. Dan Daniel Fahey - CEO President DanSources Technical Services, Inc. 1010 Rockville Pike, Suite 405 Rockville, MD 20852 301-217-0425 x 400 www.DanSources.com |
#23 |
Liked 33 Times in 16 Posts
Keep in mind a email assurance does not hold the sway of a rulebook. Tech inspectors do not carry copies of emails.
![]() "Stock replacement per OEM spec. and must check on factory spec. open and closed pressure."
Rich Taylor I/SA - 321 Last edited by HandOverFist; 12-18-2013 at 12:19 PM. |
#24 | |
As for 10 Second Pure Stockers. Here is a link of the first 9 Second ET in Stock history. Bobby DeArmond...May 9, 2001 http://www.nhra.net/fedmog/2001/news/may/050901.html Dan D Last edited by Dan Fahey; 12-18-2013 at 12:37 PM. |
#25 |
Liked 372 Times in 130 Posts
Do I have to e-mail Mike Baker to get the spring pressure numbers for my car ?
I sure hope IHRA leaves the indexes alone and just adjust the super fast PS combos with h.p. If IHRA changes the indexes, I will probably just upgrade my Mustang to NHRA Stocker specs.
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
#26 |
OK..Mike just emailed me again.
So long as the Spring fits in the Original Stock Pad. The Spring is legal. More cam and spring would eventually necessitate resetting the Pure Stock Indexes. Kind of wished they did not do that. We are in Junior Stock Range. Keeping the Stock Spring pressure would add only a little HP. This change Pure Stock should be renamed Jr Stock again! err Dan Last edited by Dan Fahey; 12-18-2013 at 01:54 PM. |
#27 | |
Interesting. Then there should be an amendment to the specs book stating: "So long as the Spring fits in the Original Stock Pad. The Spring is legal." As posted before in this thread, I would think the rulebook trumps any e-mail on raceday in the teardown area.
#28 |
I agree...
#29 |
Guest
Posts: n/a
So what will be the difference now between what a Pure Stock cam is and what a "normal" Stocker runs? Sounds like to me it will be the same cam. How much do you expect it to pick up the typical combination (if there is such a thing)?
The more I've thought about this today the less of a good idea I think it is. Scott |
#30 | |
Liked 101 Times in 52 Posts
