Old 12-15-2013, 09:56 AM   #9
kwm
kwm's Avatar
Liked 4 Times in 3 Posts
Default Re: 351C questions
Originally Posted by Bill Diehl View Post
without a girdle and spring pressure I run they flex to much...this is what I want to use
the 42/46 lifter angle matches the heads better than inline lifters...the valvetrain geo isn't even close to where it needs to be, its the only way to get these canted valve motors to run up top....I don't see where it says I can't do it
If you are using a hydraulic lifter cam these may be the rocker arms you have to use. The rules state that you must use pedestal mount rockers and as it is similar to the Oldsmobile this type of rocker arm is what we must use.
Kenny Miracle
P/SA 310
kwm is offline   Reply With Quote
