Liked 112 Times in 31 Posts
Bill,
Valve seats? Technically - No. Actually it depends on how they're installed and the valve job finished. Some ways are legal, some aren't, but these days almost anything passes I guess. Quick Fuel Carb? YES it is legal, but the secondary idle screws must be removed and the circut blocked. Pushrod side adjusters? Why? Roller rockers are allowed now. Floor mounted clutch? NO! Lifter bore mods? NO, but I'd like to see them check it. Carb spacer? NO. You can only use two factory type gaskets. I think all that is correct. If not, I'm sure someone will help out. Jerry |
