Old 11-20-2013, 10:10 AM   #11
chevy620
Banned
Default Re: Collector Tether Question
To answer the question on the extension for the slip-on collector:
I called NHRA and they said one tether will suffice but it will have to go from the Primary tube to the extension.
I would just order a kit that was long enough to accomplish that length and if you run without the extensions, wrap the cable up; it's still there and will not let them get away from the car and "being there with the NHRA-accepted tag" is what matters.
Hope that helps. They are required so it is just a matter of figuring out what you need and deciding on what tether kit is right for you.
Jok Nicholson
chevy620 is offline   Reply With Quote
