Re: Collector Tether Question
The problem that I see is that this got dumped on every racer as opposed to the facilities. Some tracks have 'burn out boards' behind the burn out area to avoid anything flying off of slicks into whatever is behind them. How many of you have been hit by a rock? I've even seen them fly into hoodscoops and into engines. Greg Dreher has his side window blown out by a rock, they spent the next half hour picking up the crumbled glass out of the staging lanes before the race could procede. Someone left a wrench on dragster at Woodburn, it fell off during the burnout, shot out from under the tire and broke a girl's leg. Are we going to have tethers for wrenches that you forgot to remove from your car also? This isn't a header problem, this is a track issue. Forget the tethers, mandatory back boards at tracks is a no brainer and would fix the problem.
