Liked 9 Times in 6 Posts
if there is nothing why is one rated at 315 and the other 317? If you want this issue to be about nothing have NHRA make both versions same HP right?
Sean Gaffney SS/G & SS/H 1223 AA/S & A/S 1008 |
The 315 hp is a 1969 300/315 041 head engine. The hood is not a factor
Tony Janes 7941 STK, SS |
#3 | |
Liked 64 Times in 14 Posts
If you have proof there is a value post your proof
Mark Callanan 1027 STK |
Marc, that is my point exactly, why different HP ratings because of the hood you are campaigning? All I am saying is that wether you have a flat hood or a cowl hood it shouldn't matter and compromise the HP rating. It should be 315 or 317 just make it the same for all.
It has been a while but I could run faster with the cowl hood with stock air cleaner base sealed to hood.
Guest
Posts: n/a
If there is no difference why do people put them on instead of a stock hood? Because it looks cool? Being able to seal the carb to the hood is worth something, at least is was on my Firebird, and those scoops are in the wrong spot compared to a cowl hood on a Chevrolet. It doesnt cost a 1000.00 dollars to put a hood on one of those cars. You can by a brand new replacement for GM for under 300.00. Maybe this will go away, or people will have extra hoods for that new 300 Hp 350 or a big block project.
Liked 444 Times in 145 Posts
A friend who has years of experience with this combination put his flat hood back on a couple years ago. He said there was no additional performance to be found in the air hood. I believe he also said the flat hood is 18 pounds lighter.
Bruce Noland 1788 STK |
Liked 71 Times in 23 Posts
I have a 69 camaro flat hood I would sell if someone needs one. I can bring it to Indy points meet. It is primer, I took it off my 69 and put a cowl on it. The car is going to be a street car, so I did it for looks. It is a original GM 69 flat hood.
Monte Howard 3209 STK, 3208 SS |
#9 | |
The hood after market is 349.00 for a decent one Shipping was 250.00 And what do you thinks its going to cost to custom match a custom paint job? 300-400?
Guest
Posts: n/a
