Liked 10 Times in 6 Posts
ALMACK, the stick cars got hp last year to 248, the auto cars got 13 hp 3-13-12 and 9 hp today to 257. Tom
Tom Moock 5704 STK |
#2 | |
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() |
Liked 7 Times in 5 Posts
link to the picture of the tire and wheel combo for the 2013 CJ
Roland http://www.fordracingparts.com/parts...KeyField=22553 |
#4 | |
Liked 373 Times in 131 Posts
When those 3v CJ engines came out they started @ 230 hp. Laughable, because they had special cnc ported heads, big cams, a hi-flow intake, and huge throttle body. Before it's all said and done I predict the factored hp on that engine will be @ 300.
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
Liked 653 Times in 89 Posts
Just for the record they were rated 235hp to start. (Per NHRA's request)
I wish you clowns would get all your facts right before talk or post. I predict the stick 281ci will stay at 248hp-253hp all year The only thing that is a joke is you clowns jacking off on your key boards. I wish one of you would bulid a 2010 CJ 281ci STICK. That is if you have the extra 70k around.
Charley Downing 3548 STK |
#6 | |
Liked 12 Times in 4 Posts
Wow Charley, I'm impressed. A real generalization about all those who are on the board posting and their habits. Makes you look more like a clown than the most of us(there's always someone on every board that looks like a clown most of the time). The only reason you talk like that is because you own one of the cars with a very favourable HP rating. I'm quite sure you'd be just like many others here if you still had a different combo.
Everyone know's the HP ratings are a joke, but the fact you have the factories pushing these soft combos and you don't have to look deeply for an odd combo like some racers have done in the past, makes for a lot of soft combos and not just a rarity, is disturbing to many. I'm not knocking the fact that you were wise enough to play the game to your advantage, just that your post was in very poor taste as you implied everyone here(except for you) is a clown and you know that isn't the case. JMT.
#4892 J/SA. We are what we repeatedly do. Excellence then, is not an act, but a habit.” - Aristotle |
To those that don't believe the Cobra Jet Hp factors are too soft:
http://www.racingjunk.com/Stock-Supe...COBRA-JET.html From the add: This car will run 1.50 under in E/SA at over 100lbs. heavy, with 6 quarts of XP3, timing backed down, and shifting 500 rpm early! No ice or chiller needed. If you let it run at its peak, it can go more than 1.70 under. You can also set this car up to run at whatever you like in minutes! #1 qualifier at the Infineon NHRA Divisional and National events. Qualified #6 at Vegas to avoid the AHFS trigger. ONLY RUNNING TO THE 1000' MARK EACH TIME! Only 17 passes made since new.
From Belle Rose CIC Race..... when you can't get hurt!
3697 Brad Zaskowski E6 ****WINNER**** 0.098 10.898 123.02 J/S Index: 12.35 (+/-): -1.452 It doesn't matter how you find it, old or new. There have always been soft HP factors.
Sam Tufano |
Liked 128 Times in 41 Posts
Wow......now "we" have to impress our moms?
Good stuff.....
Sean Cour T6066 ladle Last edited by Sean Cour; 03-21-2012 at 07:09 PM. |
