Old 01-15-2012, 11:53 PM   #21
John Kelley
Default Re: 10.5 Tire
Originally Posted by kenny wigington View Post
10 oh and lots of faster cars will hook fine on 9". If you cant make that work, go to ss or bracket racing until you do.
Amen !!!
John Kelley is offline   Reply With Quote
Old 01-16-2012, 01:02 AM   #22
NWDragracing
Last year I spoke to the Goodyear drag racing engineer that happened to be at Pomona. I brought up the subject as regards to the high speed in Stock Eliminator with their 9" on the CJ's and DP's.
His response was the tire is designed and tested for speeds over 160 mph and cars up to 4000 lbs. He also stated, just like Mark/A56 shared, that it is up to the racer to have the appropriate suspension setting to run the high speeds.
NWDragracing is offline   Reply With Quote
Old 01-18-2012, 04:15 PM   #23
Bobby Fazio
Bobby Fazio's Avatar
I thought dot drag radials were legal as long as they weren't larger than 9" or 94 circ?
'65 Mustang SS/L & L/SA
Old 01-19-2012, 03:12 PM   #24
Casey Miles
Liked 508 Times in 92 Posts
They are in D2, my friend has a Corvette that he drives to the NHRA national and division races, he uses drag radials.
Casey Miles
248H Stock?
