Old 11-23-2011, 01:26 AM   #11
Bernie Cunningham
Liked 52 Times in 17 Posts
Default Re: 2012 Rules Are Posted
Originally Posted by SS Engine Guy View Post
Aftermarket rockers. And more spring pressure. And nothing about ratios which will work much better with different ramp angles on cams which will require more spring pressure. Speeding up opening and closing intervals. And you can only get so much spring without bigger diameter valve pockets. (next change) Sounds reasonable to me------------In SUPERSTOCK. If you can't make a stock rocker live with the mods allowed you probably should be running in a class that already allows aftermarket rockers. Not screwing up a class that is screwed up enough by all the whining, and aftermarket BS that has already been allowed. As many have stated deregulating spring pressures caused this.
Just what we need, or so I'm told, more classes. I thought the manufacturers wanted less classes? Which is it?
X2 , where the heck did this come from ????!!!!!!!!!!!!!!!!!!!!
just go ahead and dilute us again cause of a few whinny people (or rich) get there way!!!! sounds like US politics, buggar !!!!!!!!!!!!!!!
Bernie Cunningham 7053 STK
Bernie Cunningham is offline   Reply With Quote
