Old 11-22-2011, 10:47 AM   #41
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Default Re: 2012 Rules Are Posted
Originally Posted by cutta View Post
So are all of the super stock only cars with 6.0lbf weight breaks going to be allowed back in? I have to say that I would love to see one of the 68's cudas or darts in stock. At least that would add some additional excitement and even amidst all the unrest of NHRA's idoacy(if thats a word), seeing some of the SS only combos in Stock would be exciting.
Not backhalved they shouldn't be.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 11-22-2011, 12:30 PM   #42
vic guilmino
Liked 56 Times in 21 Posts
ed
why not
you can't buy a mustang or a dp from the dealer
i think that would be cool and a 289 snake
Vic Guilmino 1129 STK
Old 11-22-2011, 01:48 PM   #43
cutta
cutta's Avatar
Liked 5 Times in 2 Posts
I was referring to current stock legal darts/barracudas to be allowed to convert over to a hemi and run in one of the new classes since the weight breaks are for super stock only.
Adriel Paradise, Paradise Racing Team
Driver/Crew Chief(at least my dad claims me to be)
B.S. Mechanical Engineering, University of Arkansas
cutta is offline   Reply With Quote
Old 11-22-2011, 02:45 PM   #44
Charley Downing
Liked 653 Times in 89 Posts
Vic
If you are having trouble getting new CJ cars or parts Just call VARSITY Ford Ann Arbor Michigan. just ask for Joe in parts he can get you any CJ part or you can place an order a 2013 CJ
Open 6 days a week.
Charley Downing 3548 STK
Charley Downing is offline   Reply With Quote
Old 11-22-2011, 04:07 PM   #45
GUMP
Liked 2,361 Times in 558 Posts
I purchased my Drag Pak from Southland Dodge.
Old 11-22-2011, 04:10 PM   #46
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Looks prety simple to me..........
The cylinder head rules in Stock didn't change and that states "The following are permitted: polylocks, jam nuts, screw-in larger-diameter rocker studs or pinned studs, bronzewall valve guides"
The ONLY rule that chaged was the ability to use aftermarket rocker arms and they did NOT have to be (as the old rule was) "Aftermarket rocker arm must be identical to OEM. Either adjustable pushrods or adjustable OEM rocker arms permitted on any application, but not both. OEM roller rockers permitted ONLY if application was originally equipped with roller rockers"
The difference is now the rule says "Aftermarket rocker arm permitted. Either adjustable pushrods or adjustable OEM rocker arms permitted on any application, but not both.
Looks like stud mounted roller rocker arms for the OEM stud mounted engines and T&D's for the OEM shaft type rocker arms.
I don't like the rule but is seems pretty clear on what their intention was.
Bob Mulry 7516 STK
A & M Motorsports
Last edited by Bob Mulry; 11-22-2011 at 04:12 PM. Reason: aluminum center section on OEM only
Old 11-22-2011, 05:40 PM   #47
Jim Kaekel
Liked 535 Times in 110 Posts
I wonder what will be acceptable for pedestal mount rocker arms like Olds or some Fords?
Jim Kaekel 3836 STK
Old 11-22-2011, 05:44 PM   #48
Stephen & Horace Johnson
Liked 165 Times in 54 Posts
Originally Posted by Dallas Kelly View Post
Apparently, one of the 2012 enhancements will be that "all" window nets will expire after 2 years. 2011 rules had an two year expiration term for the "mesh" type nets only; "ribbon" type nets did not expire.
Maybe we can get the manufacturers to put both our two year seat belts and two year window net in the same box so that we can "save" shipping? (sarcasm)
ok why is this happening??? So i guess before to long the jackets, neck braces, and gloves will have to be renewed?
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 11-22-2011, 05:55 PM   #49
Paired shafts, like the Harland Sharp offerings, or stud mount conversions.
Old 11-22-2011, 06:32 PM   #50
7423
Alan
You mention stud conversions for a small Ford 5.0. IMO, that would take machining the head to accept a stud and milling the pedestal to accept a guide plate, correct??
That would be a no no as I am told............am I wrong and lots of racers have done this and that makes it ok? I would love to go to a screw in stud and a guide plate and toss the dumb azz shims kits in the trash.
7423 is offline   Reply With Quote
