View Poll Results: Opinions on consolidating classes
Combine Sticks and Automatics 33 14.73%
Spread Weight Breaks (i.e., .5 for upper classes, .75 for some, then to 1.00 lb breaks) 22 9.82%
Both of the above 36 16.07%
LEAVE IT ALONE! 133 59.38%
Voters: 224. You may not vote on this poll
Old 11-24-2010, 04:51 PM   #11
Owen S Quirion
Default Re: Consolidating Classes
Originally Posted by Alan Roehrich View Post
Jim,
They CAN be fairly and correctly merged into the other classes. Math works the same regardless of which end you put the slicks on. The argument that FWD cannot be merged into the lower classes of Stock holds no more water than the argument that you can't buy cams, rings, pistons, and converters for them. None. Both of those arguments hold less water than a screen door on a submarine.
There is established average ET data for the FWD cars just like there is for RWD cars. Therefore they can be properly factored.
No, the laws of math and physics apply to FWD cars too, they can race in classes with RWD cars.
Alan, You are kind of right and kind of wrong. You make a good point with the availability of cams, converters, etc... but just in case I've missed something for the last few years, where would I find let's say a set of 4.88, 5.00, or 5.13 gears because I would like a nice set. That would allow me to run a slick with a decent contact patch instead of the tiny little 20 inch tall M/T's that I have to run today in order to mask the fact that I can't get a little bit of gear. Maybe you never thought about why all of the FWD cars run the small tires, now you know. The other thing you need is a little physics refresher, yes the math works but the physics don't. You see, all cars whether FWD or RWD react the same way under acceleration, the reaction causes the front end to rise, thus helping the RWD gain traction with the big gear and the big tire. The FWD is just the opposite and very challenging to correct within the rules. I won't even get in to Fuel Cell placement and Battery relocation advantages. So, yes they could be merged but it would need to be done at the HP level, believe me.
BF/S 1985 Grand Am 3.0 V6
Owen S Quirion is offline   Reply With Quote
