View Poll Results: Opinions on consolidating classes
Combine Sticks and Automatics 33 14.73%
Spread Weight Breaks (i.e., .5 for upper classes, .75 for some, then to 1.00 lb breaks) 22 9.82%
Both of the above 36 16.07%
LEAVE IT ALONE! 133 59.38%
Voters: 224. You may not vote on this poll
Old 11-24-2010, 01:07 PM   #13
Liked 1,911 Times in 428 Posts
Default Re: Consolidating Classes
Stick and automatics should be rated the same. Its the same friggin' engine.
I disagree. Some engines simply work much better with a stick than they do an automatic. Some engines work well either way. Considering the wide variation of bore/stroke ratios, rod/stroke ratios, carburetor sizes, and cylinder head CSA's, just to name a few factors, to say that all engines work equally well with sticks and automatics is simply a generalization that cannot be true, nor can it be supported.
