View Poll Results: What would you do?
Report him 25 26.88%
Give him a chance to do the right thing 58 62.37%
Ignore the situation 10 10.75%
Multiple Choice Poll. Voters: 93. You may not vote on this poll
Old 09-24-2010, 02:14 PM   #7
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Default Re: What would you do?
Originally Posted by race watcher View Post
Do you think the infraction of the rules is an advantage? Does this competitor race in your in your class and effect you directly ie heads up? Has this competitor been through tech and tear downs? If the answer is yes to these questions use the same technology and beat them. If you cannot then move on.
I would submit that it makes no difference whether or not the offender is in your class or not, or effects you directly. If you KNOW the racer is in violation it is your duty to your fellow racers to say something. I would suggest speaking with the offender, if that gets no results, then go to the proper tech official.
By your way of thinking, if the guy uses ported heads then you should use them also! Move on? No. It's called RULES. They are there for a reason. Jim
