#12 |
Liked 806 Times in 246 Posts
You are correct about the Fairlane FE motor fit. 'Slip Fit' is the correct term, you simply smear grease on the shock towers and 'slip' it in. The trick is finding someone with long skinny fingers to start the header bolts.
Jim |
