#11 | |
Liked 13 Times in 9 Posts
- Re: Stockers running -.80 under in Super Stock.... so factor those combinations properly! I ran a Stocker in Super Stock in 2008 that happens to be a bloody fast Stocker, and it typically ran -.15 under in SS. Not -.80 under. Refer to the broad brush, above. - Re: moving indexes even more... .80? Why not whack them 1.40? Then it'll be just like Comp. Congratulations. Or is it only okay to move the indexes just far enough so that a given individual can run under anywhere, and it's only those lazy SOB's that are slower than "that" guy that need to "work harder"? - As King Ed mentioned earlier, if they whack .30 across the board, you'll have to run what is currently -.80 under just to "earn" a Class trophy on a single, and presumably to set a Record that's currently at Minimum as well. - Plus anything Toby said. ![]()
