Old 10-23-2009, 12:46 PM   #11
dragster2006
dragster2006's Avatar
Default Re: What do you guys think? Drag car or Street car?
Originally Posted by goinbroke2 View Post
Fox body stripped down for racing should be 2700 or so. (less if using fibreglass or chromemolly etc) So I would say 300-350hp should be enough to have fun with. A 5.0 with cam and aftermarket heads/intake/headers on a stock 5.0gt shortblock will give you enough.(5.0gt's come stock with forged pistons,roller cam, bottom end good for 6500rpm) or you can run a 351. Chevies can be cheaper but the cost of sbf to sbc is really minimal now.
So, you got a sbc, glide or t350, 4:11 rear gear. Don't wind it too tight as that will eat your budget. Sub frame connectors, update the rear arms(axle?) all the standard fox tricks and you'll have fun. When you want to go faster build the motor up a bit, but don't go crazy as it's a bracket car. You'll have more fun in a more consistent reliable car if you run a bbf or bbc at 5500-6000 all day long then 7500-8000rpm small block and changing springs etc every half season.
Yeah I'm a big ford guy and don't like to see crossbreading as there is no excuse for it anymore, but I'm not going to scream and jump up and down about what somebody else is doing....unless they're in my face about it.
im most def gonna find a t350 tranny for sure i found a decently priced one and its a B&M TH-350 street/strip automatic because its only like 840 bucks i believe. also my friend mentioned to me that i should get some ladder bars so im gonna look into buying those.
Rock Chalk Jayhawk! KU!!!
dragster2006 is offline   Reply With Quote
