Old 10-23-2009, 09:56 AM   #11
goinbroke2
Liked 405 Times in 158 Posts
Default Re: What do you guys think? Drag car or Street car?
Fox body stripped down for racing should be 2700 or so. (less if using fibreglass or chromemolly etc) So I would say 300-350hp should be enough to have fun with. A 5.0 with cam and aftermarket heads/intake/headers on a stock 5.0gt shortblock will give you enough.(5.0gt's come stock with forged pistons,roller cam, bottom end good for 6500rpm) or you can run a 351. Chevies can be cheaper but the cost of sbf to sbc is really minimal now.
So, you got a sbc, glide or t350, 4:11 rear gear. Don't wind it too tight as that will eat your budget. Sub frame connectors, update the rear arms(axle?) all the standard fox tricks and you'll have fun. When you want to go faster build the motor up a bit, but don't go crazy as it's a bracket car. You'll have more fun in a more consistent reliable car if you run a bbf or bbc at 5500-6000 all day long then 7500-8000rpm small block and changing springs etc every half season.
Yeah I'm a big ford guy and don't like to see crossbreading as there is no excuse for it anymore, but I'm not going to scream and jump up and down about what somebody else is doing....unless they're in my face about it.
