Old 11-07-2022, 12:18 AM   #20
Rory McNeil
Liked 1,112 Times in 304 Posts
Default Re: Billet cams and lifter supply
Originally Posted by Stan Weiss View Post
If the EPA is the problem than making the parts outside the USA would fix it.
How many vehicles today run OHC on bucket setups? Which is nothing more then the cam against a flat tappet
Stan
Totally different situation. The OHC engines with buckets have no rocker arms, lifters or pushrods, so the valve springs are generally much less tension, since the weight of the valve train is so much lighter. Even more so with a 4 valve head, since the valves are considerably smaller, as are the spring diameters and retainers. Also, the buckets do not need to rotate like a flat tappet cam, and the cam lobes are not ground on a taper, to promote rotation.
NHRA 6390 STK
M/S 85 Mustang
