Old 06-29-2023, 07:23 AM   #41
GUMP
Default Re: new A/FX CLASS
Originally Posted by JeremyDuncan View Post
As long as the shipping weights are some what close to what the cars actually weigh. Not 500lbs+ lighter.
The problem here is all of the modern cars have at least that much that can be legally removed.
When I match raced Robin Lawrence, I had over 400 lbs of ballast in my COPO. If I were running the production LT1 the only major difference is the hood. Where do I put another 500 lbs?
Daren Poole-Adams
NHRA Stock/SS 2007
Old 06-29-2023, 08:46 AM   #42
JeremyDuncan
Liked 355 Times in 80 Posts
It's called shipping weight not weight with legally removed items. Older cars face similar issues. Ask anyone racing a Corvette in Stock or SS.
JeremyDuncan is offline   Reply With Quote
Old 06-29-2023, 08:48 AM   #43
Henrys Toy
Liked 520 Times in 176 Posts
Smile Re: new A/FX CLASS
Good morning to all,
Just on the "silly side" I've always found the Cheese Burger, Pizza and Beer diet to help add a couple of Pounds right in the drivers seat. Legal ballast and a good artery clogger as well. Probably easier to find an over weight driver then a skinny one! Enjoy the Pizza and Beer and lets go racing!
Respectfully,
Henry Kunz 1534 H/SA
Henrys Toy is offline   Reply With Quote
Old 06-29-2023, 08:49 AM   #44
JeremyDuncan
Also we are referring to production cars being put in the guide, not Copo, drag Paks, & CJ's
Old 06-29-2023, 09:37 AM   #45
GUMP
Yep. And like I said, there is very little difference between my COPO and a production Camaro in legal Stock Eliminstor trim. Just the weight of the hood and intake manifold.
The new cars are nothing like the old cars. The seats, wheels, wiring, modules, rear cradle, transmissions, emissions, safety, equipment, etc. have made them stupid heavy in production form.
Daren Poole-Adams
NHRA Stock/SS 2007
Old 06-29-2023, 09:41 AM   #46
JeremyDuncan
Factory Hood instead of carbon fiber+30lbs
With production car you have to run the battery in the front where they were put by factory. So front battery and add one in the back. +50lbs
Use factory seats instead of light weight race seats +120lbs
With production car in stock you can even use back seat +75lbs
Instead of light weight 3 or 5 gallon fuel cell use max allowed 16gal fuel cell or even better heavier stock fuel tank. +75lbs
No rule that a car has to be built with chrome moly instead of mild steel. Mild steel cage with few extra bars +90lbs
Add factory spare tire and jack. +45lbs
NHRA allowed 500lbs of permanent mounted ballast.
Walla 4000lbs LT1 2023 SS Camaro.
Old 06-29-2023, 09:49 AM   #47
JeremyDuncan
And yet they are suppose/expected to run under the same rules.
Old 06-29-2023, 09:49 AM   #48
GUMP
Well, you just described a car that no one would build!
On another note, I have been told to make it clear that it is FX not A/FX.
Daren Poole-Adams
NHRA Stock/SS 2007
Old 06-29-2023, 10:07 AM   #49
JeremyDuncan
And there are hundreds if not thousands of cars in guide that "no one would build".
Should we manipulate the rules so the other unfavorable cars in the guide will be built?
Old 06-29-2023, 12:44 PM   #50
onefarmer
Liked 153 Times in 35 Posts
Originally Posted by Keith 944 View Post
Someone please explain to me and to the casual observer/fan. What is the difference in that Camaro and any other pro stock? Other than a different engine combo, they look identical. Is there really a need for another class? Most of the X pro stocks in comp are the same way, no difference to the fan…. Sorry I thought it was a great idea at first but then realized that’s what pro stock used to be before a loss of parity and so now the all Camaro show that it turned into. I would’ve loved to of seen them somehow fix pro stock invest more into that instead of creating several more classes that just may not work.
The FX cars must be the same dimensions as the stock production cars. Same engine rules apply for FX as FSS, larger rear tire and 5 spd. The FSS cars could go below 7.50 with out the constant rule adjustments and NHRA does not want any passes in the 7.5s with these cars. The FSS are 1000 lbs heavier with half the rear tire and make more power than the prostocks do. The FX cars should be much safer to run than the FSS and take away some of the limitations of the small tire and chassis of the FSS.
FX L177, FSS L177
STK L177
Lenny Lottig MMPS 77
onefarmer is offline   Reply With Quote
