Old 12-31-2007, 01:36 AM   #1
Philip Saran
Liked 14 Times in 11 Posts
Default Fuel Line Question
I've got my fuel cell for my Duster project, it has a #10 fitting at the rear for the
line to the electric fuel pump/filter setup.
I want to run a 1/2" line to the front of the car to feed the Holley carb/regulator.
Should it be metal or Aluminum or S/S braided line??
Is Summit as good a place as any to purchase fittings and lines?
If someplace local is better, I'm in Southern California near Disneyland.
As always I'm open to opinions and comments.
Thanks in advance.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 12-31-2007, 04:07 AM   #2
Dave Goob Cook
Dave Goob Cook's Avatar
Default Re: Fuel Line Question
I'm tight, so I used the -8 braid to the filter mount, then the soft aluminum (properly routed, secured, flared for AN with sleeves and nuts, and with bulkhead connector tabs welded to the frame at each end) and another short length of -8 to the pump inlet (block mount), -6 from there to the carb.
Got away for less than $150 on the job iirc.
Steel braid is a replacement item a few years down the road, pick your poison.
I'd say the aluminum line is the lightest.
You can use approved woven pushlock all the way also.
Dave Goob Cook is offline   Reply With Quote
Old 12-31-2007, 11:22 AM   #3
76 RACER
Now about that block mounted stock fuel pump!
76 RACER is offline   Reply With Quote
Old 12-31-2007, 11:59 AM   #4
Dave Goob Cook
I had to ditch the original off the 267 when I changed the fuel lines......darn car went so fast I had to put a roll bar in it, that led to fuel cell, that led to fuel line, that led to one of them there racy Holley fuel pumps that is all shiny and stuff, so I could move the lines around.
I still have that original if you need it.....
I think I voided my factory warranty......
Old 12-31-2007, 09:56 PM   #5
Joe Martens
Joe Martens's Avatar
Liked 196 Times in 69 Posts
Another route you can take is # 10 braided to the pump, then # 8 to the regulator. Earls makes a synthetic braided line that will not dry out like like standard braided. Braided is more costly but is easier to route. Summit does have a good selection of fittings and hoses. Good luck.
Joe Martens AA/Stock 3969
Joe Martens is offline   Reply With Quote
Old 01-01-2008, 02:42 PM   #6
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Thumbs up Re: Fuel Line Question
My car has the "twist-loc" hose on it from the fuel pump forward........not to high to by & easy to work with! (it looks & acts like rubber hose)
Old 01-01-2008, 04:36 PM   #7
Dave Goob Cook
You could replace that outlet fitting with a -8 also.....
