Old 06-02-2014, 01:43 PM   #1
Dave Jung
Dave Jung's Avatar
Liked 5 Times in 5 Posts
Default 60 ft varies and no wheel speed in burnout
Last weekend I had trouble burning out. No smoke and guys watching said I had no wheel speed during burnout. Also felt funny when coming out of water onto dry part of the track. Then on Sunday my 60 would vary .07 and of course et would also be way off. It felt like it was spinning and it was definatly not picking up the front end like it should when the 60 was slow. Then when the 60 picked up, it felt way better on the launch. Guys watching said I was not spinning. Did it in both lanes. Converter going? I thought it might be carb or fuel, but with the wheel speed issue in the burnout, I'm thinking converter. Thoughts?
Metric 200 and ATI 8 inch treemaster
Thanks
6535 stk
81 Malibu K/SA
Dave Jung is offline   Reply With Quote
Old 06-02-2014, 01:49 PM   #2
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: 60 ft varies and no wheel speed in burnout
Does the trans fluid smell burnt?
Rich Taylor
I/SA - 321
Old 06-02-2014, 01:54 PM   #3
Dave Jung
Dave Jung's Avatar
No, fluid is good.
6535 stk
81 Malibu K/SA
Old 06-02-2014, 01:57 PM   #4
HandOverFist
My guess would be to try another convertor. While you have it out look hard at the stator support shaft...sheared one in my metric.
Rich Taylor
I/SA - 321
Old 06-02-2014, 01:58 PM   #5
Steve Williams
Convertor.
Steve Williams is offline   Reply With Quote
Old 06-02-2014, 06:05 PM   #6
Signman
Liked 269 Times in 99 Posts
Had similar issue with my 200, couldn't do a burnout seemed like it was all on the converter and the car kept slowing down. New there was something wrong but was going rounds, the car kept slowing, lost in the semi. A clutch pack was burned up the cause may have been a slightly long drive shaft pushing the stack forward. Repaired and freshened the trans and converter also shortened the drive shaft and problem never reappeared.
Old 06-02-2014, 06:21 PM   #7
Chris Hill
Liked 244 Times in 26 Posts
Definitely check the stater support on the metric 200.
Chris Hill
Old 06-04-2014, 09:10 AM   #8
Steve Cozakos
Dave,
Give me a call, (425) 985-6285.
Steve Cozakos
Steve Cozakos is offline   Reply With Quote
Old 06-04-2014, 02:37 PM   #9
jmantle
Liked 172 Times in 81 Posts
Dave, if I recall correctly your 200 has a pressed in steel stator support. They don't break but will occasionally spin out the serrations. Put a big set of water pump pliers on it and make sure it won't turn. If you need a convertor quick, call Grant Eldridge, I think he still has one for sale.
Jim Mantle
jmantle is offline   Reply With Quote
Old 06-04-2014, 03:23 PM   #10
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Production 200/200-C have a one piece casting for the pump cover and stator shaft. Is there an aftermarket company that makes a pump cover with a pressed in stator shaft ?
