Old 05-28-2024, 08:58 AM   #31
Rick J
Liked 73 Times in 37 Posts
Default Re: Best place to buy Rotella
Another area that can get analysis paralysis.
Ring seal and rod bearings will tell you all you want to know.
Rick J is offline   Reply With Quote
Old 05-28-2024, 09:32 AM   #32
JP1738
JP1738's Avatar
Liked 1,226 Times in 343 Posts
Very true. I've been using the Rotella/Lucas Oil heavy duty oil stabilizer combo on the same rods, block, and crank for the last 9 years. Have yet to hurt or spin a bearing. The stocker/flat tappet cam has yet to show signs of weakness but I haven't made enough runs to justify the oil combo yet. Time will tell. Much appreciate all the input and opinions on this post though, I will definitely consider putting a better grade motor oil in my stocker, might even find a touch of hp going to a higher performance oil.
Dawson Pauley
#2827 N/SA 1980 Malibu SW 2S 305/180
#2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide
JP1738 is offline   Reply With Quote
Old 05-28-2024, 10:15 AM   #33
Barry Polley
Guest
Posts: n/a
Originally Posted by jcw31 View Post
I have friends who race mini sprinters with 600 cc motorcycle engines , buzz then 12000 rpm every lap their engine builders recommend rotella 15w40 .
Just sayin.
Maybe because I’m told they use methanol? Would be my guess.
Old 05-28-2024, 11:27 AM   #34
jcw31
Liked 6 Times in 6 Posts
yes they use methanol and to a previous reply they are 4 cycles not 2 strokes, but between the rpm and lots of laps it holds up well,and im not saying its right but it works and im sure they can use whatever they want .
I just dont understand the statement its diesel oil it cant work !
jcw31 is offline   Reply With Quote
Old 05-28-2024, 08:37 PM   #35
I never said diesel oil can't work. I said diesel oil producers, who blend it, strongly recommended against using it in gasoline engines due to the higher operating RPM, and the possibility of foaming and aeration.
Old 05-28-2024, 08:56 PM   #36
Originally Posted by 1347 View Post
I am not sure where you got that detergents arent for race oil, but when I talked to Gibbs(driven) about using their BR30 in a race engine all the time, they recommended I don't because the break in oil has no detergent but their race oils do. That's why you get the separation in the K&P oil filter with BR30. I trust what they say
Not sure what you mean by separation, but I stopped using Driven because with every grade and type, both break in and race oils of various weights, we ended up with a ton of thick, grey, gelatinous slime in the bottom of the oil pan, regardless of which filter we used, the premium Delco, the Wix race filters, and K&N. It looked a lot like molybdenum disulfide paste. Can't say if it ever really hurt anything, but I certainly didn't care for it.
Old 05-28-2024, 11:45 PM   #37
Originally Posted by JP1738 View Post
my stocker....... my engine builder prefers 30wt for his engines. .
C'mon man...
Old 05-29-2024, 03:09 AM   #38
Rick J
Same reason I stopped using it.
Old 05-29-2024, 07:27 AM   #39
Steve Stasko
Liked 274 Times in 143 Posts
I have had the same issue with VR1.
Old 05-29-2024, 10:14 AM   #40
RKelliher
Liked 182 Times in 61 Posts
To jcw31, I never said the 600cc engine were 2 cycle. again why spend thousand on a motor and use oil not for race engines. your choice
RKelliher is offline   Reply With Quote
