Old 05-20-2024, 03:48 PM   #1
JP1738
JP1738's Avatar
Liked 1,225 Times in 343 Posts
Default Best place to buy Rotella
Hey all, I'm looking for the best place to buy Rotella straight 30wt. Although their 15-40 would probably be fine for me to run in my stocker and S/G car, my engine builder prefers 30wt for his engines. 30wt is twice the cost of 15-40, so I'm looking for the best place to find a deal on the straight 30wt. Cheapest I can find it anywhere is about $30/gal. Tips or alternatives would be appreciated, thank you!
I will note that I always add 1qt of Lucas heavy duty oil stabilizer for added protection, and I could use a deal on that stuff too. I use it quite a bit of that as well. I usually change the oil in my stuff about every 40-50 runs or so.
Dawson Pauley
#2827 N/SA 1980 Malibu SW 2S 305/180
#2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide
JP1738 is offline   Reply With Quote
Old 05-20-2024, 03:58 PM   #2
nickh
nickh's Avatar
Liked 650 Times in 194 Posts
Default Re: Best place to buy Rotella
Would think that Walmart would be the cheapest. When i had my diesel used only rotella. As for additive look at Bestline Engine Treatment, they sell the bottles on Amazon. I sell their engine treatment, fuel treatment and transmission treatment in 55 Gallon Drums if interested PM me.
Old 05-20-2024, 04:11 PM   #3
JP1738
JP1738's Avatar
Wow I never thought to look there. 17.80/gal. Thank you sir
Dawson Pauley
Old 05-20-2024, 05:45 PM   #4
pmrphil
Liked 348 Times in 152 Posts
You also might want to watch the video by Lake Speed Jr. about oil additives - the Lucas stabilizer is one he had lab tested along with about a dozen others
Phil Molski
PMR Performance
S/C 1623
Old 05-20-2024, 06:21 PM   #5
Ron Miller
Liked 13 Times in 7 Posts
Are you close to a Family Farm & Home? See link below.
https://www.familyfarmandhome.com/brands/shell.html
Ron Miller is offline   Reply With Quote
Old 05-20-2024, 07:08 PM   #6
David Lee
Liked 346 Times in 126 Posts
go to tractor supply out your way
Old 05-20-2024, 10:26 PM   #7
MAURICE BLENDHEIM
Liked 284 Times in 87 Posts
WALMART 15w40 usually in a 5 gallon Container.
MAURICE BLENDHEIM is offline   Reply With Quote
Old 05-20-2024, 11:34 PM   #8
Barry Polley
Guest
Posts: n/a
And the Delvac 668/295 fluid is there..
Old 05-20-2024, 11:55 PM   #9
Rory McNeil
Rather than mixing in a ZDDP additive, I prefer to use an oil that has it built in. I have been running Brad Penn/Penngrade 1 10/30 and 5/30 oils in my flat tappet and hydraulic roller stuff for quite a few years now, and have had no cam or lifter issues. Over the years, it appears that the Shell Rotella oil has had the ZDP content reduced more than once.
NHRA 6390 STK
M/S 85 Mustang
Old 05-21-2024, 06:27 AM   #10
Rick J
Liked 73 Times in 37 Posts
Continue to do what has worked in the real world for you and your engine builder.
For a stock or super stock application hopped up for class, Maxima PS0 oil straight worked great with 35 lbs. oil pressure at the stripe, the narrowed rod bearings looked new after 30 runs.
Rick J is offline   Reply With Quote
