Old 05-22-2024, 08:49 AM   #21
JP1738
JP1738's Avatar
Liked 1,225 Times in 343 Posts
Default Re: Best place to buy Rotella
Originally Posted by monte385 View Post
Have you checked Summit?
They don't carry Rotella. All good though, I took an earlier suggestion and bought 10 gallons of straight 30wt at 17.50/gal from Walmart.
Dawson Pauley
#2827 N/SA 1980 Malibu SW 2S 305/180
#2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide
JP1738 is online now   Reply With Quote
Old 05-22-2024, 04:06 PM   #22
lorenr
Liked 19 Times in 9 Posts
Why would you use Rotella In a gas engine? True, I've always used 5W-40 full synthetic in my diesels. Why..
By the way Wal Mart brand Super Tech 5W-30 has always equated to Mobil One, so I've used it. Never an issue.
Someone made a comment a week or so ago about a newer light weight oil that makes 3 horsepower on a 400 HP motor. What gives?
lorenr is offline   Reply With Quote
Old 05-23-2024, 12:43 PM   #23
Barry Polley
Guest
Posts: n/a
Without knowing base and additive packages in these specialty oils especially after covid … I would be hesitant about adding anything.
I do not pretend to be a chemical engineer.
Old 05-25-2024, 06:09 PM   #24
Mike Miljanovic
Mike Miljanovic's Avatar
Liked 6 Times in 6 Posts
Hello; I heard that Shell has reduced or eliminated ZDDP from their formula (pressure from the EPA!) Rislone makes the best additive; contains both zinc & phosphorus. The STP additive is way too viscous & only contains zinc. We use synthetic oil in our stocker: 5w20 in spring/fall & 5w30 in the hot weather. (for what's it worth)
Mike Miljanovic is offline   Reply With Quote
Old 05-26-2024, 11:05 AM   #25
Couple of things to note.
1. It's not at all a good idea to play chemical engineer with motor oil. As described by Lake Speed in the video, you could be literally mixing up something quite detrimental to your engine.
2. Be aware, diesel oils are for engines that do not normally even run at the RPM your gasoline race engine runs at to break in the camshaft if it has flat tappets. As such, the diesel oil will foam and aerate.Even just as you break in your camshaft. Air is not a good lubricant for an engine, especially not a race engine.
3. There are good oils designed specifically to break in your engine, including your flat tappet camshaft.It pays to use them. Brad Penn makes a good one. Among others.
Take from that what you will. Free advice might be worth what you paid for it. Or it might be priceless. Y'all think about it.
Old 05-26-2024, 02:47 PM   #26
RKelliher
Liked 182 Times in 61 Posts
I agree with allen on this . Rotella has zinc in but also has detergent witch you don't want in a race engine. Why would spend 10's of thousand of dollar to build a race to then cheapin out with none racing oil and cheap filters. Race oil and good filter are a lot cheaper than a engine...My thoughts
RKelliher is offline   Reply With Quote
Old 05-27-2024, 10:19 AM   #27
1347
1347's Avatar
Liked 1,001 Times in 276 Posts
I am not sure where you got that detergents arent for race oil, but when I talked to Gibbs(driven) about using their BR30 in a race engine all the time, they recommended I don't because the break in oil has no detergent but their race oils do. That's why you get the separation in the K&P oil filter with BR30. I trust what they say
Duane Hoven
1342 SS/GT
1347 is online now   Reply With Quote
Old 05-27-2024, 12:02 PM   #28
RKelliher
I don't know who you talked to at Driven, but their break in oil does have detergent in it. But this thread is about using diesel oil in race engine. Diesel oil has a high amount of detergent in it. Not got for race gas engines to have high detergent. will cause zinc film to be removed from engine parts. SAE did a technical paper series 2007-01-3999 that states this problem. So use what ever you want.
Old 05-27-2024, 06:40 PM   #29
jcw31
I have friends who race mini sprinters with 600 cc motorcycle engines , buzz then 12000 rpm every lap their engine builders recommend rotella 15w40 .
Just sayin.
jcw31 is offline   Reply With Quote
Old 05-27-2024, 08:13 PM   #30
RKelliher
You're comparing motorcycle engines with 4 stroke racing engines?
